Question about HP Pavilion N5350 Notebook
Operation system not found
What would cause this to happen and how do you fix it?
  • spottazz Nov 20, 2007
    changing the cable did not work..any other ideas??? I have tried contrl alt delete esc but it asks for a password? when it prompts me to setup
  • dillonreifer Feb 10, 2008
    i have had my notebook for awhile and now when i turn it on all that comes up is Operating System not found. What do i do to fix this?
  • 81 Answers
FRND,
Change the Data cable of the Harddisk Drive...
Posted on Nov 19, 2007
Operatering system not found
It may caused by master boot record corrupted, you could use your own windows installation CD to repair it, during boot from the disk there is an repair option. If you do not have installation disk you could use 3rd party tool to rebuild MBR, like AOMEI Partition Assistant to rebuild MBR
Sep 08, 2012 | Computers & Internet
My aspire one netbook says missing operating system what do i do
On my Dell Insprion Windows 7, I have got "Missing Operating System not found" error, to fix problem,Windows Boot Genius helped me finally!
Apr 01, 2012 | Acer Aspire One D257 Netbook
When booting the laptop it says PXE-E61: media
When you start your computer, the motherboard searches connected drives for the operating system. The search order is usually the optical (CD/DVD) drive first, possibly a USB drive next, then the hard drive. If none of these work, some systems are set to try booting the operating system over a network cable. What the cryptic message you're getting is telling you is that the system tried a network boot without success, and that maybe the trouble is a bad cable.
This all means that your hard drive isn't being detected, or that there's no longer an operating system on it. It's possible the connector from the hard drive to the motherboard has come loose, which can sometimes happen since laptops get moved around. The hard drive may have gone bad, or there may be a problem with the motherboard that is causing it not to find the hard drive. Or the hardware may all be fine, but something (a virus or other malware, for instance) has deleted files needed to load Windows.
When the computer first starts, you'll see a message about how to enter BIOS setup. The BIOS is the motherboard's built-in program, and through the setup pages you can see what devices it detects. This will let you know if the hard drive is being found. Some boards include diagnostic tests you can run on the hard drive if problems are found. You can also check the boot order; you may find that for some reason the boot order has been changed so that the network boot is being tried first. Strange things can happen to BIOS settings, often a sign that the backup battery for the memory where the settings are stored is getting weak.
If you have access to a Windows XP operating system CD, you can set the BIOS to boot from the CD drive and try using the Recovery Console feature. Information about this can be found at Microsoft's site.
Good luck getting your laptop back up and running quickly. Thanks for using Fixya!
May 29, 2011 | Acer Computers & Internet
Operating system not found
Hi there. The thing that caused the shutdown is a software conflict. Go to the windows advanced option by pressing F8 key when you see the Dell Screen upon restart of the computer. Choose "Disable automatic Restart in system error" and press enter. That should fix your problem.
^_^
May 18, 2010 | Dell Inspiron Mini 10 Netbook
The system operating system not found
You will need to format and reinstall the operating system.
insert the windows/restore cd, turn on the power, press a key when it directs you to and run through the setup process.
Sep 27, 2009 | Fujitsu Siemens LifeBook N3010 Notebook
Toshiba satellite wont start up, operating system not found
Hello my friend, regarding on your problem since you bought that laptop 2 weeks ago i presume that your laptop is currently under warranty so to avoid warranty void kindly return it to the supplier or the shop where you buy that laptop in order to ensure that they will accomudate your laptop cause it is under warranty. Also let them check and fix the problem cause the problem of that laptop found inside meaning the BUS or connector fromo your motherboard to your hard drive which is why it cannot found the Operating System cause it does not locate and detect your hard drive where you stored you Operating System.
Hope this will able to solve your problem using this recommendation. If you  need more assistance just reply to this post. If you find this recommendation/solution able to help your problem solved please rate this solution. Thank you and Godbless.
Jul 09, 2009 | Toshiba Satellite A100-S8111TD Notebook
Operating system not found, hard disk not found message showing in IBMT20
On my ThinkPad Notebook Windows 7, I have got "operating system not found" error, to fix problem, Windows Boot Genius helped me finally!
Dec 26, 2007 | IBM ThinkPad T20 2647 Notebook
HP Pavilion N5350 Notebook Logo
47 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
