Question about Frigidaire ATF6000ES Front Load Washer
Humming noise, want start cycle
I have a problem with my front loader, its making a humming noise and agitater is not moving, water remaining in machine and it did not finish its cycle?
    Sergeant:
  • 187 Answers
pls try this link
http://www.acmehowto.com/howto/appliance/washer/diagwasher.php
pls rate my suggestion......
Posted on Jul 20, 2009
My new LG front loader washing machine makes humming-buzzing noise when starting (only hot washing from 60C and above)
it is buzzing because it is try to let in hot water and is activating the hot water inlet valve/solenoid
Sep 06, 2015 | LG Washing Machines
MY GE front loader washer won't fill with water or spin. I hear a hum when I turn it on and it sounds as if it's about to start a cycle but nothing happens.
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem:
1) check to make sure the water is on
2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc.
3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
May 19, 2012 | GE Washing Machines
Wont agitate unless you move the agitator
defective motor,,,start whindin gone ,,,replace motor
Jan 17, 2009 | Maytag PAV2300 Top Load Washer
Kenmore washer won't agitate,drain or spin.
What you have here is a broken drive coupling
the part looks like this:
To fix it CLICK HERE
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
My front loader has stopped in the middle of the cycle.
you need to clean your pump something is stuck not allowing the pump to drain
Dec 25, 2008 | Washing Machines
Simpson esprit 750
machine stopped moving round --goes through the cycles --the agitater just woun't spin out --makes a humming noise
Nov 01, 2008 | Washing Machines
Frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Front loader problems
call repair before warranty runs out...possible door switch if it's a loud humming noise ..try pressing in on door latch side to see it hum changes
Sep 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing machine noise
check the dogs in the agitater
Mar 25, 2008 | Whirlpool GSC9455 Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
211 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
