Question about Kenmore 62622 Microwave Oven
My lamp is out (the one inside the oven) and I don't know how to get to it so I can replace it.
  • goway Jul 21, 2009
    The issue is "locate the lamp cover". I think that knowing to remove the cover and replace the bulb is beyond obvious, but where the heck is the lamp cover? Now that the oven lamp is out, it is not at all obvious where the lamp is/was and therefore not obvious where the cover is.
    I think I may have found it on the opposite wall from the hinges, held in by one screw up from the bottom and several tabs / slots. I need to kill the power because it's full of wires and connectors.
  • 491 Answers
LOCATE LAMP COVER GIVE A GOOD CLEAN YOU SHOULD SEE A SMALL SKREW TURN AND REMOVE COVER THEN REPLACE BULB
Posted on Jul 20, 2009
How can I replace lamp?
The lamp is inside the oven. You will have to remove the outer cover but in doing so you should be aware that you will be exposed to potentially lethal voltages, even with power disconnected.
Jan 08, 2016 | Microwave Ovens
Model r-9h55. Where is lamp located and how do I replace it?
The lamp is located inside the oven. It is accessed for replacement by removing the outer cover. Be aware that potentially lethal voltages are exposed, even with power disconnected.
Nov 26, 2015 | Sharp Microwave Ovens
How do I change the lamp in GE microwave model je1590sc001>
The lamp is located inside the oven. You have to remove the outside cover to access the lamp asembly. You should be aware that removal of the cover exposes potentially dangerous voltages. With the cover removed, remove the old lamp and instal lthe replacement. Reinstall the outside cover.
Feb 17, 2015 | GE Microwave Ovens
Replace lamp
Most lamps are replaced from a door on the side of the oven if not then there must be a way from inside
Nov 29, 2013 | Magic Chef MCM1110B
I have an amana convection/microwave model acm1580as that needs a lamp replaces. I bought replacement lamp and after practically tearing appliance apart I located burnt out lamp. Now I don,t know how to...
Hi, since you have located the burnt lamp, all you need to do is to unscrew the burnt lamp and replace the new one by screwing it in.....
You only need to unscrew to remove the lamp and if you cannot remove by unscrewing because it is stuck in, then you need the assistance of an electrical tech to help remove with his pliers....
Mar 26, 2011 | Amana ACM1580 Convection Microwave Oven
How to change the light bulp inside the oven?
Bulb replacement is not straight forward on this model, it requires the oven to be removed & stripped to gain access to the interior lamp... I recommend replacement by a Siemens engineer.
Mar 02, 2010 | Siemens HB77L25GB 900 Watts Convection /...
Lamp burnt out; can I replace it? everything else still works ( carosel, clock etc.)
there are usually access panels to replace lamp, it may be inside oven or on outside case or you may need to remove cover to access lamp,be careful especially if you need to remove cover,even after its unplugged
Jul 20, 2009 | Panasonic Microwave Ovens
Hi there - need to open up my Samsung M7145 microwave to change the oven lamp which has blown. Any idea on how to get access?
hello ,
remove lamp form inside microwave oven . put new lamp , this very easy to remove, oven stop cover open also very easy . this lamp easy to get any electrical shops.
Nov 04, 2008 | Microwave Ovens
Oven Halogen Lamp
It's pretty simple to replace the light without having to remove the oven from the wall...as long as you have an offset phillips screwdriver...
Of course, be sure to disconnect power to microwave and be sure not to touch the new halogen bulb with fingers.
STEP-BY-STEP:
First, remove upper vent panel and remove inner filter (same directions for just replacing inner carbon filter):
Then, remove inner plastic grille (2 screws) and final screw on left side of metal "air duct" - here's where you'll need the offset screw driver (and a little patience!):
Then, you can gently lift the sheet metal panel, find the light housing, squeeze and remove/replace :)
That's it...just replace bulb and reverse for reassembly. Be sure to keep track of screw locations there are various sizes/lengths used.
Doug
Aug 04, 2006 | GE Advantium SCA1000H Convection /...
Kenmore 62622 Microwave Oven Logo
108 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
