Question about KLH ASW10-120 Subwoofer
Sub woofer keeps blowing fuses
I just recently moved and now my sub woofer won't come on . I replaced the fuse and it came on for 5 minutes then went out. Ireplaced the fuse again and it blowes then immediatly. can you help please I really like this sub
  • 1 more comment
  • gene O Jan 01, 2008
    The original fuse was a 2 amp 250 volt T fuse. I replaced it with a 2 amp 250 volt fuse from Radio Shack and it keeps blowing the fuses,
  • Anonymous Sep 02, 2008
    I keep replacing my 2A 250Volt fuse, the second I plug in my subwoofer to an outlet it keeps blowing fuses. What can I do? Who fixes sub woofers for good prices?
  • carmonav Sep 24, 2008
    i have the same sub with the exact same problem, i have to agree its a great sub when working. if anybody has a serious solution please help out would like to keep it instead of replacing it with a definitive technology sub i have borrowed from a friend they have the same sound quality.
NO dont try a 3 amp fuse.It is made to BLOW if there is a problem. That sub is not worth fixing, JUNK it. There are a lot of problems with it. Such as heating up and melting the board witch could cause fires. Thats what happened to mine. Like I said JUNK it and buy a different one.
Posted on Dec 13, 2008
Try a 3 amp fuse
Posted on Jun 24, 2008
Boston micro 95pv sub-woofer is blowing 3A Slow Blow fuses.
I would expect a shorted component in the power supply
Sep 06, 2016 | Boston Acoustics Micro90X Speaker
Why does the fuse blow Instantly?
Link for the service manual: http://elektrotanya.com/pioneer_vsx-305_405.pdf/download.html On page 50 of the manual (36 of the pdf) it says for the "Sub woofer pre-out jack (Not available on the VSX-305 model) If you want to boost the low frequencies, connect to a subwoofer power amplifier" Your model will not drive a sub-woofer with out another amp. His sub may be a powered sub?
Aug 31, 2014 | Pioneer VSX-305 Receiver
What is happening to my sub woofer????? D: So I have the sony muteki HT-DDW1600 and have had for the past year. In that time it has served its purpose for many many house parties. Recently I noticed that...
If a fuse blows it won't self-heal when you cycle power.
Swap the subwoofers between the two subwoofer speaker feeds. Maybe it will stay with the channel or maybe it will follow the speaker and make next steps easier.
Jul 20, 2011 | Sony MUTEKI HTDDW1600 Theater System
Hi, we moved the sub woofer from its original position and now it keeps blowing fuses. I would like to repair the sub woofer, as it works well and is quite new. I live on the south coast of NSW...
Where was it sitting before it was moved? Did it have it have more ventilation and keep cooler? This sub has a powerful amplifier in it. If it got moved to an area that restricts air circulation around the sub more it is possibly overheating and causing fuses to blow. Put a fan on it and make sure it is on a hard surface or up off the carpet at least to keep the bottom side cool as well. Also when one moves a speaker it's often to put it into a more convenient area to be able to turn it up louder with less disturbance to others. This will draw more power and create more heat within the amplifier than it's previous location. If this is so keep it as cool as you can and turn it down every so often to give the amp a rest. The key here is to keep it cool as you can. One thing you never want to do is put a higher rated fuse in than the unit is rated for. Always use factory recommend fuse rating.
Mar 22, 2011 | Klipsch Synergy Sub-10 Subwoofer Speaker
Mission m-cube sub fuse keeps blowing
If you have replaced with the correct rating and the fuse blows off then you will need to check for higher current drain in the sub woofer or the network. After replacing the fuse load up the subwoofer slowly, reduce the bass and as you increase check at the point the fuse blows off. Now we need to analyse if the rating of the amplifier you are using is rated for the subwoofer. If your subwoofer has a higher rating you can increase the rating by about 25% and check again. Some amplifiers give a very higher voltage on full bass which could result in such a condition. Moderate this and check again. If the fuse stays Ok you can continue with this new rating.Otherwise the output of the amp at higher volume needs a confirmation. Hope this helps. Good day
Jul 20, 2010 | Mission M-CUBE System
Sub-Woofer blowing fuses.
You should open it up and look for a short. Usually, an exposed wire is touching metal. Wrap the wire with electrical tape and look for a ground wires that are loose. That will blow fuses too.
Feb 15, 2010 | Harman Kardon HKTS 7 System
I have a rotel rb970bx. I have 2 and ran them in mono driving a speaker each. I tried to biamp the speakers with one amp driving the tweeters and one the woofers. This worked for about 4 minutes at 1/4...
hi
it sound to me that when you biamp and driving speaker and woofer , you are over loading the fuses , suggestions
uprate the fuses till they stop blowing
Dec 21, 2017 | Rotel Audio Players & Recorders
Psw1200 paradigm sub woofer
If your fuse keeps on blowing after you cg=hanging,that meens that there is a shortage.check it first using the multimeter.good luck.
Dec 28, 2008 | JBL PSW1200 Speaker
Onkyo sub woofer
You will only blow fuses and resistors if there is a short of some kind you can change fuses, resistors and capacitors all you like if you don't find the short they will just keep on blowing. It maybe something as small as a bit of conductive material or fluff or dust on chip board wipe board down make sure it is clean (a clean toothbrush is perfect) and there are no signs of burns on either side of the chipboard befor you change anything. If there are burns or greenish build up clean them with some metho or water on a cloth not to damp though and make sure Burn or corrossion hasn't taken off the protective layer on the board.
Then try new fuses. Hope this helps you
Jul 25, 2008 | Onkyo TX-DS676 Receiver
Subwoofer issues
The fuse blows when the current that passes through it are beyond its rating. This could be brought about by excessive consumption of the load, in this case the amplifier powering the sub-woofer.
Repairs would involve component level and require that you be familiar with electronic components and circuitry, use of a DVM and a soldering iron. Often it is just the finals that needs to be replaced. Of course we cannot discount the possibility of other components or section such as the power supply.
The smoke indicates something heating up such as a resistor or diode or a capacitor.
Should you be uncomfortable opening the unit and doing a DIY (do-it-yourself), then perhaps you need to seek the services of a qualified professional.
Should the downtime and cost of repair be no longer economically reasonable, purchase of a new unit might save you further trouble.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 23, 2008 | Onkyo SKW-200 Subwoofer
KLH ASW10-120 Subwoofer Logo
1,537 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
