Question about Acer Aspire One Netbook 8.9" Notebook
30 Seconds or else!
Mine gives me 30 seconds to reboot. It attempts to do just that but can't get ther in time so it just shuts off.
  • Aaron Monello May 11, 2010
    Can you give us more info? are you getting into windows at all? can you get into the bios?
  • 76 Answers
Corrupt Hard Drive. You may need to start over and reinstall Windows
Posted on Jul 20, 2009
Kindle fire hd is frozen. Was trying to exit out of Silk. Will not shut-down/power off. Has been at 82% power since this afternoon. Tried plugging in to charge - still will not shut-down.
Soft Reset:
  1. Hold the power switch for twenty seconds. You will need to slide the power switch along and hold it for twenty seconds before releasing it. ...
  2. Your reboot screen should appear when you release the power switch.
  3. Give your device time to reboot for a minute or two.
  4. Turn the Kindle Fire HD back on
Nov 28, 2016 | Tablets & eReaders
How to Reseting lg298cm cell phone
This may not be the only solution, but give this a try:
Try pressing and holding the "Volume Up" key and the "Power" key at the same time for about 30 Seconds. After 30 seconds (or a bit less) that Phone will reboot and the problem should be fixed. If that does not work, try the same with the "Volume Down" key.
Thanks
Sunny
Oct 12, 2016 | Cell Phones
HOW DO I UNDER FREZZER MY KINDLE
Hold the power switch for 20 seconds. Slide the power switch and hold it in place for 20 to 30 seconds before releasing it.
  • You need to physically hold the power switch in its off position for this long. Doing so tells your device to "reboot," in essence, instead of merely shutting down.
  • The reboot screen should appear as soon as you release the power switch.
Give the Kindle time to reboot. The Kindle will reboot within a minute or two. Be patient and give your device ample time to finish its reset.
  • There is some possibility that the Kindle will freeze as it reboots. This may be the case if your Kindle stays frozen on the reboot screen for more than ten minutes.
Charge the Kindle. If the device freezes during the reboot or does not respond to the reset at all, plug the charger in and allow your Kindle to charge for 30 minutes or more.
  • Make sure that your Kindle has enough time to complete a full charge.
Hold the power switch down again. After you finish charging the Kindle, slide the power switch and hold it down for another 20 seconds.
  • The reboot screen should appear again. Give the device a minute or two to reboot before checking it again. This should complete the reset.
Jan 01, 2015 | Amazon Kindle 3G
Aspire ahows green light but won't start up, have turned off main but still just green shows
Pull the plug from the AC outlet, wait a 30 seconds, plug in, try to reboot. Does it try to start and in a few seconds shut down? Give as much detail as you can.
Dec 19, 2012 | Acer Aspire™ T135 PC Desktop
Harmony touch reboot continually
Here is a confirmed solution - it helped with mine Harmony Touch:
- Press and hold the Off and Menu button for 30 seconds
- Log in to you Harmony account
- Connect the remote to PC and sync it.
Oct 31, 2012 | Televison & Video
My Intel D945GCCR Motherboard shutsdown automatically after 30 seconds on bios without os
your processes fan is damage please check processes fan and fan heat sing
Apr 22, 2012 | Intel D945GCCR Motherboard
How do i reboot my computer
To reboot the desktop machine, kindly press the power on button for few seconds / small button(reset) below the power button to reboot the computer.
If its laptop follow the below steps
Determine what operating system it uses. Finding out what operating system your laptop uses will let you know what key combo (such as "Ctrl+Alt+Delete") can exit you from usage and trigger a reboot or shutdown.
Try and reboot using the operating system. Attempt to use the key combination that will allow you to exit from the operating system and restart the laptop. Be patient, as it may take some time if it has locked up.
Hold down the power button. If the operating system's answer to the rebooting will not work, find and hold down the power button of the laptop. This should cause the device to shut itself off. You'll have to press the power button again to power it back on, completing the reboot.
Unplug from the wall and remove the battery. If restarting via the operating system and the power button do not work, unplug the laptop from the wall outlet, and remove the battery from the laptop. This will cause it to power off immediately.
Allow time to reboot. Give the laptop time to cool down before you power it back on if you had to do this manually. A few seconds should do unless you have additional problems.
Oct 15, 2010 | Computers & Internet
Way to reboot ac system?
Most of the time, if the system is shut down by a fault code, you just shut the power off to the furnace and a/c for about 15 to 20 seconds and that usually resets them.
Jun 04, 2010 | Heating & Cooling
Dymo 400 labelwriter does not print unless shut down and rebooted
It could be how you have loaded the labels. If you have loaded the labels and there is a small gap between the spindle and the roll, it will print one label and give a error-printer message and stop working until you unplug it for 30 seconds and plug it back in. I would reload the labels from scratch and ensure there is no gap.
Feb 17, 2009 | Dymo LabelWriter 400 Thermal Printer
No picture, won't turn off
Som-one,
the noise you hear after the melody would you describe it as like a buzz or a small chainsaw? If so you have a bad color wheel assembly. If the noise is intermittent than your issue could be the ballast that controls the lamp. If you've already changed the lamp the next step should be the ballast.
Dec 03, 2007 | Samsung HLN5065W 50" Rear Projection...
Acer Aspire One Netbook 8.9" Notebook Logo
35 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
