Question about Panasonic TH-50PHD5UY 50 in. HDTV-Ready Plasma Television
Video no Sound OR Sound no Video: Pick your poison
We have a Tanberg video confercing unit attatched and after switching through all the output setings on the TV and video cinference unit and cannot get the two to sync. Here are some photos, any help would be great.
0 characters
1 Points
My problem is how to connect marantz audio video receiver 680 to LED samsung 42"
Hello, you need to connect the sound output and video output of the TV. To the entry of sound and video of the amplifier. Should match the cable type, the type of connection to existing instruments. Usually connections are RCA connections or SCARET. Once you have connected, you need to choose the entrances of the amplifier switch, according to entries you've used. What remains is only to increase the volume. Good luck
Apr 22, 2011 | Flat Panel Televisions
I would imagine the level is too high. Does your loop amplifier not have a sensitivity control?
You could come out of the scart socket but check for a headphone volume control first!
The connection standard requires that the pins are utilised in the following manner:
Hope this is useful.
scart.gif PIN USE LEVEL / IMPEDANCE 1 Audio Output (R) 0.5V / 1K-ohm 2 Audio Input (R) 0.5V / 10K-ohm 3 Audio Output (L) 0.5V / 1K-ohm 4 Audio Ground -------------------- 5 Blue Ground -------------------- 6 Audio Input (L) 0.5V / 10K-ohm 7 Blue 0.7Vp-p / 75ohm 8 Status (CVBS) L:0-2V H:10 - 12V / 10K-ohm 9 Green Ground -------------------- 10 Data D2B (Inverted) -------------------- 11 Green 0.7Vp-p / 75 ohm 12 Data D2B -------------------- 13 Red Ground -------------------- 14 D2B Ground -------------------- 15 Red 0.7Vp-p / 75 ohm 16 RGB Status/Fast Blanking L:0-0.4V H:1-3V / 75 ohm 17 CVBS Video Ground -------------------- 18 RGB Status Ground -------------------- 19 Composite Video Output 1V / 75 ohm 20 Composite Video Input 1V / 75 ohm 21 Case Shield ---------------------
A 21 pin SCART cable with all pins connected is wired as per the following diagram:
Jan 23, 2011 | Flat Panel Televisions
I dont seem to have an audio out port on my LG tv to attatch a sound bar, what can I do?
on the TV, there should be audio / video output with RCA plugs. usually behind the TV, exactly beside / parallel with DVD and Audio Video Input
Aug 16, 2010 | LG Flat Panel Televisions
Samsung 2333HD to dvd/vcr combo
On a DVD/VCR combo unit....the Component Output (RED, GREEN, BLUE) is exclusive to the DVD player section only (VCR can only output analogue source) and will only be able to view DVD.
To watch VCR, you will need to connect to your TV via Composite (YELLOW) cable, into the Yellow AV input on your TV. You can then tune the VCR section to match your TV's RF input (if you prefer this connection).
Good luck...
"if this has helped you, please rate this solution"
Dec 04, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
Can hear sound, but no picture
do you see picture if you watch a dvd,if no ''then the video out put circuit is bad on unit git it fix or warrantee
Aug 07, 2009 | Akai LCT2765TD 27 in. LCD Television
Use of AV2 input sound socketsto play ipod
The sound is muted unless a video signal is detected on this TV. The only work around would be to connect the camcorder or some other active video to tha input but using the IPOD for the audio.
Jul 23, 2009 | LG RZ-17LZ21 17 in. LCD Television
I can't seem to hook up my Insignia T.V. and my dvd player up
The way to hook up the dvd player to the television to to put a cable into the output signal section of the dvd player( Ther may be many different ways to hook-up the signal s-video and component video, regular video. You must pick one of these output signal sources to put into the input section of your television by matching them up i.e s-video out to s-video input compnent video output to component video input, regular video out to regular video input. For each of these video hook-ups there will also be a set of two sound cables. Look on the back of your television for the signal input section and hook up the video cables and the sound cables to your selected input. You should do this with both units turned off in order not to damage the circuits by shorting them on cable insertions ofr causing heavy feedback in the circuits. One this connection is complete. Trun on the television first and select the TV's signal source . By pressing the input button and using the up and down arrows to find the correct selection. By matching up all three sources you now should have the correct signal path. Turn your DVD and test the controls. try using the volume control and use you dvd to to play,ff, or stop the dvd.If all this works then you have done the set up correctly and can now enjoy your dvd's on the television Hope this helps you with your problem..
Mar 23, 2009 | Insignia 37" LCD Flat-Panel HDTV
No sound on pc connection
HDMI outputs from devices such as DVD players do carry both video and audio, but the HDMI output from your computer video card only carries video. You'll need to connect a cable from the computer sound output to the TV as well.
Feb 25, 2009 | Sony KDL-26U2000 26 in. LCD Television
Toshiba 50HP66 Plasma TV
Found that video 1 and video 2 switching does not work. The switching IC was HOT!. Then found a third video input works but no sound. Hooked -up sound output of DVD player to amplified loudspkr and it works, I hate to throw away a 2 year-old plasma TV when TV and cable still works.
Thanks for the offer anyway.
Oct 12, 2008 | Toshiba 50HP66 50 in. Plasma Television
Panasonic TH-50PHD5UY 50 in. HDTV-Ready Plasma Television Logo
21 people viewed this question
Top Panasonic Flat Panel Televisions Experts
Are you a Panasonic Flat Panel Television Expert? Answer questions, earn points and help others
