Question about Sewing Machines
I need to know how to replace my needle threader in my baby lock emp6. that is how to remove the old one and put the new one in.
  • memecb Jul 20, 2009
    i haven't tried it yet so don't know. where are the pictures can't seem to find them
  • 3,037 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Replacing the Needle Threader Part, P/N XC5732051
The instructions for this process can be found in the service manual page 4-26. I’ve come up with some short cuts per say. This should take maybe 15-20 minutes to do, (never did time it though). Item #3 will only apply if your machine isn’t at #1 needle position. The other steps apply to all. I’m sorry if some pictures aren’t very clear. My camera couldn’t zoom in close enough to see and be focused. This isn’t to take away from any dealer’s business. Feel free to have your dealer replace it if you want.
Removal
1. Remove Needle #1. If more room is desired remove needle #2.
2. Looking at the machine needles, Pic1. To the right you will see a white plastic cover that covers a screw. I use the needle screw tool (small allen wrench tool). Stick it in the hole of the cover and with slight pressure the cover will come out. Now remove the screw under the cover
3. With your machine off. Press & hold all 3 buttons on your LCD panel (Start/Stop, Scissors & Threader). Turn on your machine. On the next screen select “Main Board Test Mode”. Now select “Needle Position“. Pic 2 shows this screen. At the lower right of this screen are 4 arrows. 2 single, 2 double with a number in between them. That number is the current needle at the needle threader. Select the single arrow that will move the Needle bar & needle position to 1. Select Close.
4. Now select “Thread Set Motor test”. Pic3 shows this screen. At the lower left is “Manual Move”. Select it. This will move the needle threader out like it’s starting to thread and stop.
5. I advise having a good light for the area to be worked on. Look closely at your new threader. You will see a small plastic piece sticking out with a tab at the end of it. Now look at the silver shaft, You can see where this tab fits, into a groove. I used the small screwdriver that came with the machine. Place the screwdriver at the large of the threader and push to the left and slide the threader off of the two shafts, Pic5. You may have to lift the small tab out of the groove while doing this. CAUTION!! There is a small spring the threader is hiding. You’ll see it as the threader slides off the shaft.
6. Now for the reason of removing the case screw. Slightly pull the case to the right as you remove the threader. You’ll have to wiggle it out between the needle arm and machine. It can be done.
Install
7. Make sure the spring is still there. Slide the needle threader back on both shafts. The longer shaft will move some, don’t worry. It can’t go anyplace do to the case in the way. If you follow the silver long shaft you will see a large end with an allen setscrew in it, Pic4. There is a hole in the arm it fits through which is larger than the shaft but not too large the large end will fall through. The large end will fit right in the hole when you are done. Hold pressure on the large end while you press on the threader. Push the threader on until that little tab falls into the groove of the shaft. I had to put pressure on the large silver end to get the threader all the way on. It’s a snug fit on the shafts. When the threader is in place over both shafts and locked in place the large end of the silver shaft should be in the hole.
8. Replace the case screw and plastic cover. Turn off the machine.
Let me know how this turns out.
Benjamin
Posted on Jul 20, 2009
Baby Lock EMP6 needle is hitting the bobbin system and breaking up,
Your machine has been knocked out of time. Take it for service.
May 05, 2017 | Baby Lock Sewing Machines
I'm looking for an operation manual for this particular machine, how or where can I find one, tried Baby Lock website downloads, and couldn't find one, please help.
Baby lock is the company name; not the model. Anyway, you will need the model number or name wherever you look for this manual.
Try this company for now:
http://www.sewingpartsonline.com/needle-threader-singer-503277.aspx
Jul 26, 2015 | Baby Lock Sewing Machines
Need replacement motor for bl4 736 baby lock pro line serger
This parts order is dependable.
Mar 01, 2015 | Baby Lock Sewing Machines
How do i calibrate the hoops on a baby lock emp6
This is a translation of instruction from the Service Manual for the Brother PR600, the twin of the Babylock EMP6. I will testify this works because I just did it to stop the insanity of my EMP6 thinking everything was a 5x7 hoop. If you look on page 4-36 of the free PR620 manual http://www.brodyrmaskiner.se/service/pr620/pr-620-service.pdf you will find the same exact set of instructions that are in the PR600 manual. So here are the exact steps to augment the manual's instructions.
1. Turn off the machine.
2. Press all three buttons (start, threader and cutter) and keep them pressed while turning the machine on.
3. Press MAIN BOARD TEST MODE.
4. Press A/D TEST.
5. Put the largest hoop on the machine (7 7/8 x 11 3/4).
6. Press LL.
7. Put the smallest hoop on the machine (1 1/2 x 2 3/8).
8. Press S.
9. Take the smallest hoop off the machine.
10 Slide the arm to where the knob on the arm is when the large hoop is on the machine.
11 The reading on the screen should be very close to the value that is in the LL setting.
12 If not, go through the large hoop steps (5-6) again.
13 Slide the arm to where the knob on the arm is when the smallest hoop is on the machine.
14 The reading on the screen should be very close to the value that is in the S setting.
15 If not, go through the smallest hoop steps (7-8) again.
16 Press close when you have both settings close. They need not be identical but they do need to be no further than 200 away from the screen value.
17 Turn the machine off.
18 Turn the machine back on, load a file, and see if you have the same results that I had; it will show the proper hoops when you press the hoop symbol and it will also center itself in the hoop properly.
You can buy the PR600 service manual online for about $12. However, you have the 620 manual for free and there is really very little difference. I have found the manual invaluable in saving me trips to the shop and doing my own repairs.
Aug 26, 2013 | Baby Lock Sewing Machines
After replacing needle, needle threader won't work. What am I doing wrong?
You probably haven't inserted the needle fully into the needle bar. Try that first.
Also check that there isn't a bit of needle shank in the holder.
Good luck.
Oct 04, 2012 | Brother Sewing Machines
Bernina virtuosa 155 solutions
Needle threader heads are actually easily replaced and should be replaced anyway every few years because they do wear-out. Get a magnifying glass and, having returned the needle to the top (use the foot controller, so that the machine stops it in the right place), pull the needle threader down until the head rotates towards the needle. Look with the magnifying glass to see if the small hooked part in the centre of the threader head (the light grey plastic part) goes through the eye of the needle - if not, you might be able to bend it VERY carefully so that it does - that should cure it. If the hook is a long way above or below the needle eye, dont try and bend it, the cam that rotates the threader has probably moved on the needle bar and will need adjustment by a service agent. If the hook is passing through the eye of the needle OK, but still not pulling the thread back through when you release it - i.e. the thread is just slipping-off, the hook has become rounded through normal wear and you'll have to replace the threader head. The threader head simply pulls off - you might need to carefully lever it off the round shaft. Replacing it is a matter of simply putting the new one on the shaft and pressing upwards firmly so that the grooves in the threader head go right up to the horizontal pin on the threader shaft.
Dec 12, 2011 | Bernina Virtuosa 160
I am not sure how to replace my broken self threader hook, to put in a new hook for my 2040 model, Pfaff sewing machine?
If your talking about the needle threader, it just simply slides on to the stainless steel shaft and snaps on. You might have to adjust it a little if it doesn't line up with the eye of the needle. To do that you need to remove the side cover of the needle bar area, and loosen the 1.5MM allen screw that sets the stop for the threader stop. It is located near the top of the needle threader bar.
May 13, 2011 | PfaFF Tiptronic 2040
Threader is not working. I press the needle threader lever down but it doesn't go all the way down and it won't spring
You may need to lower the presser foot for the needle to be in the correct position. Consult your manual.
Apr 03, 2011 | Baby Lock Sewing Machines
My Baby Lock Imagine Wave serger, won't thread the right or left needles and I have been troubleshooting for over an hour.
H
likely the needle threader needs replacing or some times straightening.
Contact me at sewaway@shaw.ca
Wayne Buss
Sew-A-Way Sewing Machines
Medicine Hat Alberta
T1A 0C9 ph 403 527 7801
Apr 21, 2010 | Baby Lock Imagine
Inapproipiate needle stop position THEN Main Motor Lock comes on
The BELT was OFF. I guess it did that during shipment to me. So my husband just put it back on. THAT SIMPLE. It just kept making a motor trying to run sound and my husband took the left top cover off and seen it was only the belt. I was SO excited. It saved me a service call.
Feb 07, 2009 | Baby Lock Imagine
Sewing Machines Logo
173 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
