Question about Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR DX Nikkor Lens
18-200 mm nikon zoom autofocus has stopped working.
Initially only stopped on longer zooms, like 150-mm or more, and only intermittently, then progressively got worse until now not autofocusing at all. Did this about 2 years ago, but fixed itself when we put a new memory card in camera!?!?  Same solution doesn't work this time. I have just managed to save some money for some new gear to help my prospect of finding photo jobs, and now it appears I may have to blow it all on another lens I already have.... Hope someone can help Thanks, Widemus
  • Sachin Gharat
    Sachin Gharat May 11, 2010
    HI I AM SAGHA REPAIRER FROM MUMBAI, I THINK THE PROBLEM IS WITH YOUR
    AUTOFOCUS SENSOR INSIDE THE LENS.IT CAN BE REPLACED BUT BETTER TAKE IT
    TO GOOD REPAIRER & GET IT REPLACED YOUR LENS WILL BE AS
    ORIGINAL.REPLY ME AS SOON AS YOU SOLVED THE PROBLEM.THANK YOU
    Sergeant:
  • 291 Answers
Your motor may have gone bad. Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Posted on Apr 06, 2010
Why does my lens only zoom to 200
Could be, because most camera's only can auto focus till f/1:5.6. And if 5.6 is reached at the focal length of 200 mm, the camera stops it from going to a part it can't be focused.
Perhaps you try the lens in manual focus, and manual zoom.
Jan 28, 2014 | Sigma Zoom Telephoto 170-500mm f/5-6.3 APO...
Nikon 18-55mm lens will no longer zoom to 55mm.
there must be a problem with the lens ring which are fitted inside, occasionally it gets worn out because of improper handling . alignments may have caused you the problem. but once again you need a professional help because you wont get any elements or parts easily except from the company.this lens could also may have jammed due to any reasons, may be a foreign body or so and because the af is OK you are still getting a sharp image up to actual 45 mm which you think to be 55mm. If i were you then I would have inverted the lens and tapped gently and then check it once again or best goto Nikon service centers .
Feb 06, 2013 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
If you had a compact camera it would say 10x zoom what is the equivilent in a 70mm -300mm tamron
A 35-80 mm lens is 2.3X zoom. Divide 80 by 35 and you'll get the result.
It is usually better to know what the focal length of a lens in "35 mm equivalent" is and judge by that, rather than relying on the "X" power of the lens. For instance, most point and shoot cameras start at about 35 mm and have either a 3X or 4X zoom. This would make it a 35-105 or a 35-140. I've seen some that start at 28 mm, though. A 3X starting at 28 mm is 28-84 and a 4X is 28-112. Neither one is a particularly strong telephoto lens and the 4X is just about the same as the 3X that starts out at 35 mm.
It's also important to realize that tradition dictates that lens focal lengths are usually expressed in terms of "35 mm equivalent," where "35 mm" refers to a 35 mm film camera. This is because of the relation between the sensor size and the actual focal length of the lens and the resultant angle of view of the lens.
I have one point & shoot that is actually a 5.8-24 mm zoom. This is a 4X zoom. The 35 mm equivalent is 28-116 mm. The sensor is 7.2x5.3 mm. (1/1.8") (And I wish I knew someone who could explain how the heck they came up with sensor size terminology!)
I have another point & shoot that is actually a 5.7-17.1 mm zoom. This is a 3X zoom. The 35 mm equivalent is 34-102 mm. "How could a shorter focal length give a longer 35 mm equivalent?" you might ask. It's because the sensor is only about 5x4 mm. (1/2.5")
I have a few Nikon DSLR's and - thankfully - they all have the same size sensor. They all have a "lens factor" of 1.5. This means that you just multiply the actual focal length of the lens to get the 35 mm equivalent and then you can make comparisons accurately from camera-to-camera. Most Canon's, for instance, have a lens factor of 1.6. On a Nikon DSLR, a 28 mm lens is the "35 mm equivalent" of a 42 mm lens. On most Canon DSLR's, the same 28 mm lens is the equivalent of a 45 mm lens.
These example are just to show you how freaking confusing it can all become if you try to make sense of the "X" power of a zoom lens.
Bottom line...
Check the 35 mm equivalent specifications for the lens. This way, you will be leveling the field and comparing apples to apples. More or less.
Jul 10, 2012 | Tamron 75-300mm f/4.0-5.6 LD Lens for...
Sigma 170-500mm f.5-5.6. fit on nikon d 200 ??? and i wild like to how good is this one 170-500mm
Sigma makes their lenses with a variety of mounts for a variety of cameras. A lens with a Canon mount, for example, will not fit onto a Nikon camera. Assuming the lens has a Nikon mount, it is fully compatible with the D200.
If you mean the 150-500mm, you can see a review at
http://www.popphoto.com/gear/2008/12/sigma-150-500mm-f5-63-dg-os-hsm-apo-af
In general, Sigma supertelephoto zooms have a pretty good reputation. However, only YOU can decide whether a particular lens is "good enough" for you.
Aug 04, 2011 | Sigma Zoom Telephoto 170-500mm f/5-6.3 APO...
I have a Nikon D3100 and want to buy a zoom lens 70-300.Please help I am confused is a Nikon AF Zoom-Nikkor 70-300mm f/4-5.6G compatible? And is it automatic focus?
That lens will work with the D3100, except for the autofocusing. In order to autofocus with the D3100, you need AF-S lenses, such as the AF-S VR Zoom-NIKKOR 70-300mm f/4.5-5.6G IF-ED or the
AF-S DX NIKKOR 55-300mm f/4.5-5.6G ED VR.
May 22, 2011 | Nikon Cameras
I have an old interchangable lense from a Nikon camera that I used to use with film. My question is does the lense Sigma DL zoom 75-300 mm 1:4-5.6, fit or work on any of the digital camera today?
Yes. It will fit and work on every current Nikon digital camera. It will act longer, like a 125-450mm on the smaller sensor bodies (everything except the D700 and the D3 series). It will act like a 75-300mm on the D700 and the D3. It also won't autofocus on some of the low-end bodies, such as the D3000, which require the lens to have an internal focus motor.
Mar 27, 2011 | Cameras
Shooting with a Nikon zoom such as 18-200 with a Nikon SB800 flash on a Nikon D300 body. I make an exposure of a person and the result is exceptable and then I zoom to the whole group of five people and it...
Depends on the zoom length. If you check exposure at zoom 18 mm then zoom to (lets say) 100 for the final picture the flash will zoom concentrating the flash power as well; the flash gets stronger. This is all explained in the SB-800 manual. On a zoom such as the 18-200 the more you zoom the smaller the f/stop. You are better off with a zoom that maintains its f/stop through the entire zoom range. That way when you check exposure at 18 mm lets say f/2.8 then zoom in it will maintain the same f/stop. Myself I am not a big fan of zooms especially ones when zoomed change to a smaller f/stop.
Aug 05, 2010 | Nikon Speedlight SB-800 TTL Flash
Just need a manual foor Nikon One.Touch Zoom 90s
Description: Sleek and stylish, the exciting new Nikon One-Touch Zoom 90QD offers real zoom power in a lightweight, easy-to-use design. The One-Touch Zoom 90QD has a sharp, clear, 2.5x zoom lens with a 38-90mm range and a macro mode for shots as close as 11 inches. The One-Touch Zoom 90QD features a built-in automatic flash with five versatile modes (auto flash, anytime flash, flash cancel, slow sync and red-eye reduction). The active infrared autofocus, infinity focus (for landscapes and faraway subjects), real-image zoom viewfinder and fully automatic exposure control all help to ensure clear and balanced photos.
7444ca6.jpg Depth 2.1 in. Film Type 35mm Width 4.6 in. Height 2.5 in. UPC 018208018789 Battery Type 1 x 3V Lithium Battery (CR-2) Weight 7.84 oz. Self Timer Yes Camera Type Point and Shoot Focus Type Autofocus Minimum Focus Distance 1 ft. ISO Range - Automatic Setting ISO 100 - 800 Red Eye Reduction With Red Eye Reduction Zoom Size 2.4 Auto Exposure Yes Min Aperture f10.5 Waterproof No Max Aperture f4.8 Zoom Lens With Zoom Lens Zoom Range 38 mm - 90 mm
User Manual can not be found up to now. Very soon will be available.
Jan 26, 2010 | Nikon One Touch Zoom 90S 35mm Point and...
Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
May 24, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR DX Nikkor Lens Logo
456 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
