Question about HP dvd740i DVD±RW Dual Layer Burner
Dvd 740b not reading blank discs to burn on
I prompt itunes to burn a playlist onto a disc & it prompts me to insert a blank disc. I insert a blank disc (memorex cd-r & memorex lightscribe) & the green light flashes on the drive then stops. Itunes then prompts me to insert a blank disc even though the blank disc has been inserted. I've used memorex without a problem before (cd-r & lightscribe); I even just recently burned 2 memorex cd's although it had taken me all day because of the same issue described. I've downloaded firmware for the hp dvd 740b, software for lightscribe, & updated itunes. I'm still having a problem. I read that maybe sonic is conflicting with another burning software which I also have installed on my comp. but what does that have to do with the drive reading blank discs. Can someone help?
  • HP Master
  • 20,706 Answers
NO PC stated dang. laptop or desk?
internal DVD drive or external HP solds all 3.
NO OS stated. windows? Windows what>?????
no real DVD partnumber stated only the usless
front bezel number 740.
if yours is marked 2001,, its going to be a big problem. 9 years past HP support.
and all old drive are weak now or scratched optics.
and drives that old were even full of bugs then
(we an link you to 10,000 pages showing that)
why not upgrade it.?
get a new drive and new fresher OS.
windows 10
and a nice new blu-ray burner.
and move on.
or if this rig (PC)
is 2001 why not go to GOODWILL
and buy a 2010 PC< for like $25
and i bet it works 10x better.
Posted on Mar 18, 2017
  • Anonymous Mar 18, 2017
    off hand it say the drives is going south
    if fresh new top brand media fails
    the drive is bad, but what new there
    its 16years old.
    also if you run media slower than 40x
    it will fail.
sandrew
  • 2961 Answers
SOURCE: problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Posted on Jun 13, 2007
SOURCE: HP dvd 740b dvd burning issues
You might try the fitmware upgrade at http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=pv-42566-1.
Posted on Nov 25, 2007
  • 23 Answers
SOURCE: hp 740e not reading blank dvd discs
Don't wanna sound like a Doomsayer but I think it has burned its last burn...
Try to clean it first, if it still doesn't work, then it is time for a new one.
Had a similar experience and we found out that the drive had conked out.
Posted on Feb 05, 2008
  • 1257 Answers
SOURCE: Cannot burn audio cd from itunes7 error code 4450
CLICK ON THE LINK BELOW TO FIX THE ISSUE
http://www.windowsguru.org
Posted on Jul 01, 2009
  • 3 Answers
SOURCE: well i recently did the windows updates and now my
I've had the same problem, but due to my video configuration I don't get a display until after I load Windows and this fix requires a bootable floppy or usb drive, so I haven't actually tried it yet. This link gets you the download for the firmware update to the optical drive, and I think it will create a bootable floppy or flash drive when you run the app. There's a 'View Directions' link right above the link to the downloadable file and the app itself instructs you on screen I believe. If this is too much then the other option of course it to replace the drive. Good luck!
Posted on Aug 08, 2009
Burn project ejects blank DVD-r
If you are prompted to insert a CD/DVD blank disc into the Burner, you must have the proper UNUSED CD or DVD blank disk. You must use the SIZE disc that corresponds to the Size of the Data to be burned. A CD is 700 Megs thus anything greater than 700 Megs needs a larger disc such as a DVD that is 4.7 Gigs. If the data you are trying to copy to a disc is over 4.7G you need a Dual Layer DVD or BluRay that accepts 25Gigs.
Dec 16, 2013 | Roxio Computers & Internet
I HAVE A SONY VAIO PCG-3B1L. MY BACK-UP WILL NOT WORK.
Is there a special media? Because blank CD-R's and DVD-R's. Plus or minus can not be formatted. It has to referring to a hard drive, SD card, or pen drive. So be carefull with those.
Oct 10, 2012 | Computers & Internet
I have had to replace my hard drive on my pc how can i get my music back on to pc from my ipod and back into i tunes
Backing up your iTunes library to a CD or DVD To burn a CD (CD-R or CD-RW), your computer must have a compatible CD burner. To burn a DVD (DVD-R or DVD-RW), your computer must have a compatible DVD burner. Check in iTunes Preferences to see if a drive is compatible. See below for steps.
To create your backup disc
  1. Choose File > Library > Back up to Disc.
  2. Select the option you want from the resulting dialog and click Back Up.
  3. The two options you can select from are:
    • Back up entire iTunes library and playlists
    • Back up only iTunes Store purchases
    Whichever of these two options you choose, note that you can also choose "Only back up items added or changed since last backup" to perform an incremental backup.
  4. Insert a blank disc (CD or DVD) into your computer's optical drive. iTunes will scan the disc and begin burning.
  5. Note: If the disc you insert does not have enough space to hold all of the content you will be backing up, a dialog will appear asking whether you wish to backup to multiple discs. You can click Data Discs to continue.
iTunes burns the number of items that fit on one disc and then asks you to insert subsequent discs to continue burning the remaining files. Don't eject a disc while a backup is in progress.
Spoken programs purchased from the Audible.com website are not backed up.
Discs you create using the iTunes backup feature can be used only to restore; they can't be played in a CD or DVD player.
Restoring from a backup disc
  1. Open iTunes.
  2. Insert your backup disc.
  3. iTunes will ask whether you want to restore from this disc. Click Restore.
Check drive compatibility
  1. Choose a playlist on the left side of the iTunes window.
  2. Click the Burn Disc button on the bottom right corner of iTunes.
  3. If the drive is listed, it's compatible.
Aug 16, 2010 | Apple iTunes
How do I transfer my itunes to another computer?
Cucusoft iTunes to iTunes Transfer is an easy to use iTunes utility designed to help you backup/recover/transfer your whole iTunes library and media files. It's a simple way to keep your iTunes in sync everywhere. You can use "iTunes to iTunes Transfer" to backup your own iTunes library or synchronize multiple iTunes on different computers. The backed up library file is pretty easy to transfer to other iTunes, and it's easy to manage. So with this iTunes Transfer software, you can manage your iPod/iPhone/... on different PCs
Transfer photos, music, videos from iPhone iPad iPod to computer or Mac by this software:
http://www.mustsoftware.com/Cucusoft-iPad-iPhone-iPod-to-Computer-Transfer-guide.html
For iphone/ipod/ipad to Mac transfer
Jul 27, 2010 | Apple iTunes
When it comes time for me to copy my dvd...it prompts me to insert a blank dvd-r...i insert a blank dvd-r and it kicks the disc back out telling me to insert a blank dvd-r. Do i have to do something...
This is a common problem. RW DVD are different types. You need to read what type of RW DVD you need there will be either a nimber, leter or symbol at the end of where it says RW DVD or DVD RW and you CANNOT use just any disc.
Mar 16, 2010 | Roxio Easy CD & DVD Burning
I want to down load a song on my computer to a disc. How do I do this?
* First you should have a CD/DVD Burner on your computer (ordinary CD player would not work).
* Load the blank disc into the DVD burner
* Open the folder where the song is, highlight the song by clicking it once.
* Click on "copy this file" and then select the DVD drive.
* Then the file should start downloading.
Have a great day!
Sep 13, 2009 | Dell Computers & Internet
Downloading my music and then burning to a cd
Have you read the section of manual relating to 'Importing CDs' ?
Select a playlist, press 'playlist edit' - press HD/CD - insert CD, close drawer. Once Alesis has scanned disc, press 'track move' - display should read Move CDTrk -> Trknn where 'nn' is the next available track in playlist. Press Cursor Left to place cursor under CDTrk, press Down/No, and display should read Move CD->Playlist. If you now hit Yes it will copy all CD tracks to the active playlist (it'll prompt if the playlist isn#'t empty to make sure you want to add the CD to the tracks already in the playlist).
Once they are copied to the playlist, you can move them around if required, DSP them, then burn that playlist to a blank CD
Dec 02, 2008 | Alesis MasterLink ML-9600
NEC ND-6650A
well, sounds like common error promblem have you tried looking and seeing if mite have bought the wrong kind of dvd's I have done this before i bought dvd's instead of Cdrw's discs.? or try dowloading www.slysoft.com thier cd player plays and reads and rewrites almost anything .. lala linda
Jun 03, 2008 | NEC ND-6650A DVD RW Dual Layer Burner
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Disc read error
Sounds like the laser has gone or the try is not fully loading the disc.
Dec 03, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
HP dvd740i DVD±RW Dual Layer Burner Logo
327 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
