Master Cool shakes, is noisy like metal hitting metal.
Have a mastercool, and the center part with the blades, can be moved from one side to the other. Not quite sure why it is loose , or where to tighten it. Will it also need to be greased?
    Champion:
  • 233 Answers
Probably should not be loose, there may be a set screw or band clamp, the motors are generally permanently lubed and do not require oil or maintenance.
Posted on Jul 20, 2009
Model # 917.289072 19.5 42" When i engage blades it is very noisy like metal on metal It seems to cut ok but I don't want to mess it up more I changed blades and changed oil
Did you check the spindle assembly. I had one that cracked on my mower and had to replace it.It could be broken at one of the corners and this makes the blade spin off balance or not turn at all.Or a pulley could be worn or bent and the belt makes it rotate against the other metal parts.This happened because I hit some stones. They can damage other parts of the mower deck as well as ruin the cutting blades.You can do an online chat with SEARS parts too and their tech may have more info which may hepl diagnose the problem. Good luck,
Jean
May 27, 2015 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Noisy
Something is catching on the fan blades. Possibly a screw or piece of plastic has come loose and is connecting with the fan blades when you switch it on. When the projector has been cool for a few hours remove the lamp and gently shake the unit to dislodge whatever is catching on the fan.
Mar 11, 2013 | Panasonic PT-AE900U Multimedia Projector
I have a 10" ROK tile saw which shakes violently
MAKE SURE THE BLADE IS RUNNING TRUE, UNPLUG SAW ! BRING THE BLADE DOWN TO THE CUTTING DECK, WITH YOUR HAND TURN THE BLADE, AND WATCH WHAT THE BLADE DOES. THERE SHOULD BE NO SID TO SIDE OR UP AND DOWN MOVEMENT IN THE BLADE ! THERE IS LITTLE WASHER KITS THAT MAKE CENTER THE BLADE TO THE DRIVE. OR IF THE BLADE WIGGLES WHEN ALL IS CENTERED, IT MAY BE A BAD BEARING IN THE BLADE HEAD.... IF I WAS OF HELP HIT THE YES BUTTON.. THANKS JAY.. THE MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 20, 2011 | Diamond Products Mk - 101 10" Tile Saw
I need a new water Pan for my adobe Master Cool Model EC630G Master Cool Cooler????? Where can I get one, and how much for cost?
You can find the parts here:
http://www.indoorcomfortsupply.com/Mastercool%20Plus%20Parts.html
I am pretty sure your going to have to order the wet section U pan for your model. (Item 19) / $249.95
Thanks for choosing FixYa,
Kelly
Mar 01, 2011 | Mastercool 67680 Evaporative Cooler Air...
Need to know the difference between a master cool and a ultra kool
They are pretty must the same design, the Mastercool was made with heavier metal. But Mastercool are no longer being made,,,, so I guess if it's a new one you are looking for,,, Ultra Cool it will be.
Good Luck,
Paul
Mar 25, 2010 | Mastercool 67680 Evaporative Cooler Air...
The shaft on the master cool is moving from side to side and it vibrates. how do I stop it from moving
You need a couple of locking collars to keep the shaft from sliding around inside the bearing mounts.
You'll have to take the pulley off and possibly the bearings to insert the locking collars in between key areas where the collars can keep the shaft from moving in and out. You'll need to know the size of the shat (probably 3/4") to know which collars to get. You can find them online at www.indoorcomfortsupply.com
You'll probably want some leather washers also to eliminate friction between metal parts.
Jul 03, 2009 | Mastercool 67680 Evaporative Cooler Air...
Squirrel cage installation.
If there is strong air flow blowing into the house the sq. cage should be OK. Possibly you need to replace the pads and make sure that the pump is not clogged and is distributing enough water to keep the pads wet.
May 05, 2009 | Mastercool 67680 Evaporative Cooler Air...
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
