Question about Samsung SCH-u550 Cellular Phone
Samsung eternity driver not recognized by Windows Vista
I recently bought usb cable compatible to my eternity and I installed the PC Studio and the driver from the Samsung Download page prior to connection , rebooted my system and still my laptop is not able to read
an error msg comes out "USB driver not recognized , device malfunction ...blah blah blah.." why is this so hard?? ...Am I missing somethin here?
My laptop does not connect with my mobile in samsung kies via usb cable. mtp usb driver installation fails.
Most probably is that your driver is not for the operation system that you now have in use..for example you used to have a Xp installed and now you have windows 7 or Vista ..so ...what you have to do is look for an update on the Samsung support site ..for your model of phone ..and the operation system you use...or ..try this software ... Samsung pc studio ..and usually it works with all windows and all samsung phones that has a usb cable ..
http://www.software112.com/products/samsung-pc-studio.html
Mar 17, 2011 | Computers & Internet
Samsung pc studio 3 is not working on my pc.it is windows 7.though the software is installed when i connect through datacabel it again asks for software.please help.
Firstly download this file and do not run yet
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=HQ&CttFileID=1946472&CDCttType=SW&ModelType=N&ModelName=SGH-F480&VPath=SW/200806/20080616115846062_Samsung_USB_Driver_Installer.exe
Then download this file and do not run yet
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=HQ&CttFileID=2344870&CDCttType=SW&ModelType=N&ModelName=SGH-F480&VPath=SW/200907/20090707085705500/Samsung_PC_Studio_323_IF5.exe
save them to a new folder on your desktop, or to a place you normally download files to (do not open or run them) right click each exe icon select properties and select compatibility tab select "Run this program in compatibility for" WINDOWS Vista (service pack 2) also enter a tick in the check box for run as administrator
do this for both .EXE icons
run the usb driver file first then run the pc studio
the USB files may fail to function at this stage, but its fine ....once you have installed pcstudio..and if you have errors on the USB files run them again....and they will work fine
1 more thing on the PC Studio icon that i splaced on your desktop after installation right click again and select properties compatibility win Vista service pack 2 and administrator..and all should work
Oct 06, 2010 | Samsung Computers & Internet
I have installed samsung pc studio that i got in a cd when i purchased the samsung sgl 700 phone. when i installed the pc studio and also the usb driver still when i connect the phone to pc the phone is...
I think so you are using windows vista....vista has usb problem you have to upgrade your vista or try this latest in win xp....try this in your pc else try in win xp....
please get the latest version of pc suite from here
http://ng.samsungmobile.com/supports/softwaremanuals/software.do?phone_model=SGH-L700
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 25, 2010 | Samsung SGH-L700 Cell Phone
Samsung C3060R driver fo Windows 7
uninstall again your pc studio, restart you laptop and reinstall your pc suite, but before you do install it, try to do this trick, right click the pc studio, select properties, then select run in compatability mode of xp and vista, then select run as administrator, select apply and ok. it will install, there are times that windows 7 will inform you that the program not installed, you will be having two options, select, '' install the program with recommended settings''.
once installed, connect your phone to your laptop, select settings on you pc suite, select connections, select usb, this will command the pc suite to search for phones attached to usb ports. once searched, it will install your phone automatically and will look for appropriate device drivers for your phone through your pc suite, once connected you are set.
if this doesn't fix your problem, try updating you device through device manager, direct your device installation by browsing the folder to your samsung pc suite and unchecking the automatically install the best driver and checking the box for include the drivers on this folder.
regards.
Mar 06, 2010 | Cell Phones
How to sync pictures from eternity samsung phone on mac
set the phone's usb connectivity option to "USB mass storage" and it will appear on your mac like an external hard drive.
Jul 31, 2009 | Samsung Cell Phones
Usb not recognized
you can try this. install pc studio, and then connect your mobile...it should automatically install the drivers..but if that is what you have done then you can try updating the PC studio software.
Nov 29, 2008 | Samsung SGH-D900 Cellular Phone
My usb cable is saying it is not recognized to windows when I plug my digital camera in to download pics. I recently bought a gateway with vista. it worked when I had XP. the camera techs say it is in the...
the camera tech may be right.
vista has new requirements and specially with drivers from camcorders,cameras...and everything else that requires you to install specific programs and drivers for that to run on a vista.
what you should do is check with your cameras website if they have one, and see if they have new drivers or software that is compatible with windows vsta.
you shouldnt have any problems doing this with XP, but with Vista, thats something else..
Apr 24, 2008 | Computers & Internet
Samsung u600 usb connection wizard
PC Studio for Vista can be found on the Samsung Website. Series is "U series" and model, of course, is U600. As for installation, as Samsung suggests, make sure that the phone is NOT connected to the USB port at ANY POINT prior to the completion of the installation. Install the software as normal. Then, after it has finished installing, open up PC Studio and plug in your phone. At this point, the software SHOULD recognize that the phone has been connected after setting it up to use USB connection in the “Connection Manager” (Click “File”, “Connection”).
If it is still not recognizing the device after plugging It in, or if it displays a message along the lines of “USB Device Not Recognized” KEEP THE PHONE PLUGGED IN TO THE USB, Go into the Control Panel in the Start Menu and open up the Device Manager. At the very bottom of the list of hardware etc, there will be a selection for “Universal Serial Bus controllers”, expand this menu and look for an item called something like “Unknown USB device”. Double click on the device and go to the “Driver” tab (I think you have to press a button on the first screen that appears in order to get to the menu driver tab. Although I can’t remember what was written on it, there was only one there). When in the Driver tab, click on “Update Driver”. Now on the wizard that appears, click on “Browse my computer for driver software” then, ignoring the rest of the page, click on “Let me pick from a list of device drivers on my computer”. Uncheck the selection box “Show compatible hardware” and scroll down the list of Manufacturers until you get to “Samsung”. Now, if you’ve installed PC Studio, you should see four separate selections for “Samsung”. Click on the fourth manufacturer selection and you should see “SAMSUNG Mobile USB Device” as a Model selection, select it and click “Next” (If, 1, you don’t see “SAMSUNG Mobile USB Device” at all, then just browse the other three Samsung based manufacturers or, if 2, you have more than one entry of “SAMSUNG Mobile USB Device” then select the top one”. Also, if Windows comes up with any warnings about installing device drivers, just ignore them). Windows will now update the driver (It actually updates three drivers). If you open up PC Studio the phone should now be recognized as connected (Assuming your prior setting up of the Connection Manager to use USB).
Good Luck.
Oct 24, 2007 | Computers & Internet
Samsung SCH-u550 Cellular Phone Logo
763 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
