Question about Kenmore 15516 Mechanical Sewing Machine
Kenmore Sewing Machine model # 385.12312100 i didn't fined it?
SOURCE: reverse on kenmore sewing machine 385
I recommend that the machine be serviced by a professional but if you're handy it may simply need cleaning around the reverse cam. To do this place the machine on it's back. You'll need to access the rod that drives the feed dogs and cam mechanism by removing all screws holding the bottom plate of the machine. Remove the bottom plate. Note that when you push the reverse button, while turning the wheel a thin rod moves left which allows a plastic cam mounted to the cam rod to also move left and engages the feed dogs in reverse. If the cam is not moving enough or if too slow, it may be that the rod and cam need cleaning and lubrication. Clean out all lint and lubricate the cam where it moves on the shaft. Try to get it to move more freely without forcing it. When done replace the bottom plate. I just repaired my wifes machine and this solved the problem. Hope it helps.
Posted on Feb 17, 2008
  • 323 Answers
SOURCE: Sears Kenmore Sewing Machine Model 385. 1254180 Bobbin Won't Wind
On some of these machines when the bobbin winder is on it stops the rest of the machine from working. Push the bobbin winder mechanism to the left and see if your machine will work.
sewman7
Posted on Jan 23, 2009
SOURCE: kenmore sewing machine model 385 16764
There's a website called managemyhome.com which is sponsored by Sears. It's free to join. Go to the Home Manager column and choose Owner's Manuals from the drop down menu.
You can type in the brand name (Kenmore) and model number of your machine. Not all of them are in there but, I did find the one for the 1950280 question. It's a pdf file.
For the 38516764 question, please double check your model number. I received either no response or a Kenmore Elite dishwasher manual in response to my query.
Posted on Feb 04, 2009
  • 37 Answers
SOURCE: I need a manual for Kenmore sewing machine 385 11703700
you can go to www.kenmore.com and then click customer care. There is a phone number to call for a replacement manual.
Posted on May 12, 2009
  • 11 Answers
SOURCE: How to thread Kenmore 25 sewing machine Model 385
Hey if you need a new manual go to this link www.ifixmachines.com and dont forget to put this code (150t) so you can get $1.50 discount. Hope this help.. By the way the manual cost only $10. BYE
Posted on Jul 22, 2009
I read on internet different sewing machine model part can interchange with one another does anyone know what model interchanges with Kenmore 8 Stitch Sewing Machine Model 158 13450 and does anyone know...
A sewing machine technician may be able to help determine who actually made the machine. The problem is, Sears negotiated with various companies to make Kenmore products and Sears frequently changed manufacturers. I believe Janome made some Kenmore sewing machines but during what period and for how long is questionable.
You can try searching for:
Make Model parts
and see what comes up.
Feb 27, 2018 | Kenmore Sewing Machines
The bobbin on my kenmore sewing machine model 158.15720 won't spin to wind the bobbin. I oiled it but it didn't help. The belt is a little loose. Could replacing it help?
most machines will have a rubber o ring as part of the bobbin winding mechanism, when you engage the bobbin winder, this o-ring will move over against the main engine drive wheel and this then makes the bobbin spindle turn. So yes, you may need to replace the rubber o-ring, they can perish and wear. Called Bobbin Winder Tyre, you could try www.sewingpartsonline.com, they have loads of Kenmore models listed but can't see yours. However, if you email them, they should be able to advise what part number it is. If you start by opening up the machine case and take a look at the bobbin winder area first, you may find this rubber has split or perished.
Oct 11, 2011 | Elna 2007 Mechanical Sewing Machine
Kenmore 15516 Mechanical Sewing Machine Logo
303 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
