Question about Royal 29549X Dictionary
My royal r74 won't turn on.
I'm pretty sure that it's frozen. I tried to take out the batteries and put them back in. After I did that, three lights on the side of it turned on. What do I do?
    President:
  • 566 Answers
Have you tried to reset it?
There will be a little hole somewhere for that purpose. Just insert and push an unbent clip into that hole for a few seconds.
Posted on Jul 20, 2009
I have a 2006 tribute that won't start, sometimes. The battery has been replaced and the alternator is not putting out quite the correct voltage but isn't really bad yet I don't think. It&
You need to replace the alternator, it may be charging the battery enough to start the vehicle for a few days, but once the battery runs low, it cant recharge the battery, would have the alternator tested, but i'm pretty sure that is your problem. Hope this helps...
Sep 08, 2012 | 2005 Mazda Tribute
1994 Toyota Tacoma PreRunner - won't start with new battery, lights won't come on
Check your battery connections on the battery and the other ends where they go the ground will go to the engine block and the positive to a solenoid make sure all of this is tight and has no corrosion. This is just a loose wiring problem
Aug 18, 2012 | 2000 Toyota Tacoma PreRunner
Acer Travelmate 3270 won't start?
Could be corrupt cmos, bad hard drive, bad memory, bad peripheral.
Remove hard drive and perform diagnostics on it to make sure it is good and not the source of issue.
Then check to see if machine is posting - if not, then you are in deep doo doo because without a posting procedure you cannot repair your OS, install a new one, nada.
A new mo bo will set you back 100 bucks on ebay: installation of mo bo on laptop is one Royal,, Royal PIA.
Sep 18, 2017 | Acer Computers & Internet
My camera is frozen and won't turn off. Can't video or anything.
Take the batteries out; this should shut it off. It should restart normally after the batteries are put back in.
Jun 08, 2012 | Kodak Playsport Zx5 Video Camera aqua
Camera completely frozen. Lens protector open. Won' start with battery or AC power. Performed hard reste, no change.
have you tried removing battery and putting it back in? also what does "frozen" mean specifically? is it frozen in the menu with buttons not working or not powering up at all?
Aug 03, 2010 | HP Photosmart R827 Digital Camera
My dreammaker spa has power and lights but the pump won,t turn on.it makes a sound for a few seconds like it is trying to turn over then it stops.it was recently running .
Sounds like the pump is jammed or the motor bearings are frozen. If you can take it apart, try the pump first. The bearings on modern motors are pretty reliable. Get everything cleaned and lubed and put it back together. Good luck...Lee
Jan 14, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
1992 Oldsmobile 88 Royale.... won't start, but all lights come on
Try turning the key to the on postion-not crank, just to he postion right before cranking. leave it in that postion for 15 min, Do this three and after the third time go ahead an try to start it. Hopefully this will reset your security for you.
Aug 29, 2009 | 1992 Oldsmobile 88
Royal 29549X Dictionary Logo
124 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
