Question about General Electric GFSS6KKXSS Stainless Steel Bottom Freezer French Door Refrigerator
Installed new bottom freezer refrigerator 2 days ago. Makes ice but only about 4 glasses a day.Plenty of water when using this function.Any ideas
  • General Master
  • 1,606 Answers
Turn freezer temp up slightly . The inportant thing is to let the ice build up before using . When it builds up closer to the icemaker , it will cool the mold quicker , therefore , make ice quicker . May take several days to build up , but should keep up with ice usage this way .
Posted on Aug 12, 2009
    Champion:
  • 363 Answers
There should be a command on the front to increase ice making or in the ice maker compartment
Posted on Jul 22, 2009
No ice in lower freezer or upper ice maker
Had Numerous similar problems for about a year, No ice in either the top or the bottom trays and the bottom leaked into the bottom of the freeze.
First thing I did was install a pump onto the water line supplying water to the ice maker inlet, thinking the water pressure was low. The pump hasn't run since I installed it six months ago so the water pressure is fine. Second I replaced the solenoid assembly thinking I had a bad unit. Still same issues.
Finally as a last resort I decided to bypass the water filter. Now both the top and the bottom ice makes more ice than I know what to do with.
It's easy to do my just using the hose couplers that are mounted on the water lines.
Second thing I did was install a 1" piece of 3/4 clear hose (available from any big box hardware store), cut the bottom end at a 40 degree angle an slid it over the fill tube going into the ice maker tray on the bottom unit. In my case the tube was just a tad too short. Be careful forcing in onto the existing fill tube as I think you can actually push it up further into the freezer housing. I don't think it's mounted very well on the inside. The tube should just be long enough to make it past the lip of the fill tray.
Last thing I did was reset the refrigerator to factory settings. I found that if I made the freezer too cold the fill water would freeze eventually coming out of the fill tube.
Nov 02, 2017 | Frigidaire Refrigerators
Freezer keeps beepimg
if the temp. in the refrigerator side is 20f, its to low, set the ref. to 40f and freezer to 0f.
Sep 23, 2012 | Liebherr CI1651 30" Built-in...
Our Kenmore Elite french door bottom freezer, automatic icemaker, no water/ice dispenser on the door - is leaking quite a bit - had to mop up the floor three times today. first time it's happened since...
Check for cracks in the water supply tube from the house plumbing valve to the ice maker. Could also be the valve itself.
Turn off valve for a day to diagnose which.
Oct 21, 2017 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Jul 23, 2008 | Refrigerators
No ice
My ice maker makes about enough to fill 2" in bottom of tray then quits making ice, whats the problem I just got it two days ago
Jul 20, 2008 | Fisher and Paykel Active Smart® E522BR...
Ice Maker Not Making Ice
Ice maker was installed properly, when you put the arm down it doesn't call for water to fill unit. It doesn't make any kind of noises at all. The water is turned on and all plugs are in there are no kinks in the line but when the arm is truned down for it to call for water nothing happens
The is for a frigidaire refrigerator.Ice maker is all new..
Nov 01, 2007 | Frigidaire 20.6 cu. ft. Top Freezer...
General Electric GFSS6KKXSS Stainless Steel Bottom Freezer French Door Refrigerator Logo
270 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a General Refrigerator Expert? Answer questions, earn points and help others
