Question about Cell Phones
The phone keeps getting a screen connect with a check mark. then after about 5 seconds it says disconnet. when it starts it does it over and over.I have the lg prada 2. I have taken the battery out and sim card out and put them back in.It still does it.
How do I bypadd screen lockbon a moto g
Do a factory reset. This will erase all internal data though.
Switch phone off. Press and hold volume up button and then switch on. Should get a menu which allows factory reset. Use volume and on buttons to navigate menu.
Mar 17, 2016 | Cell Phones
Xbox 360 netflix disconnets while watching programs why
It Sounds like you have a network problem at your home with your ip otherwise:
Netflix Customer Phone Number Shortest Wait Best Support
Phone Number
888-638-3549
Talk to a Human
Press 0 at each prompt.
Average Wait: 5 mins - 24 hours, 7 days
Phone Number
888-638-3549
Talk to a Human
Oct 05, 2014 | Netflix
My screen went out on my HTC Vivid, I already have a new phone but I would really like to get all the pictures and music off my old phone. Is there any way to access this from my computer? I didnt have an...
yes, but only if you've installed recovry into your phone.
if you did installed recovery, then pull off your battery press power+volume down button for about 5 seconds and then wait 10 seconds then after press volume down for 2 times.
connect your phone to computer
then wait for 10 seconds and press power up button for 1 time.
now press power up button for 3 times.
and then power up for around 5-7 times until you get prompt in your computer that you've connected mass storage.
if you just want to do this simply even without having recovery try to connect phone and then slide down and press exact area where you get "Connect USB" on your phone.
keep guessing till you succeed.
Jan 21, 2013 | HTC Vivid
Disconnection of net connections getting disconnet
I would first start off by suggesting to update the drivers and checking the cables to be properly and fully connected. Keeping in mind someone may have bent the cable to many times or other damage may have occurred.
Please keep us posted if this issue persists afterwords.
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com
May 24, 2010 | D-Link DFM 562IS (DFM-562IS) Modem
The i9 phone keep locking by itself when i'm using an application. How do i get rid of this? Also, it keeps popping up as "slide to unlock" like every 5 seconds. It also automatically locks it self even...
I have the same problem; only when I write a text message the phone locks itself and loses the message i was writing.... very annoying, so i'd be glad to receive some advice onm this, too...
Feb 23, 2010 | Dual Electronics CECT P168 Cellular Phone
I have no sound
Connect the HDMI cable from your PS3 to your T.V. for video, and connect your optical audio cable to your Home Theater. Hold your finger on the on/off switch of the Playstation for 5 to 10 seconds,you will have flashing blue and green lights while you hold it, then it will turn off (red). Then hold it again for another 5 or 10 secondsto turn it back on, keep holding it until the green and blue lights stop flashing. That resets the Playstation3 defaults. If you have an HDMI cable, you will see a message "HDMI cable detected, do you want to select it?" Say yes. Then you should get a second message about "Ps3 can automatically set optimal settings, yes or no" Again say yes. Now you should have audio and video through your T.V. Now to get the audio through your home theater, go to "system settings" (looks like a suitcase.) select sound settings...the PS3 should have selected HDMI already, change it to digital optical, and then move right to the optical settings, put a check mark in "Dolby Digital", and "PCM 44 mhz", and "48 mhz.." DO NOT...and I repeat DO NOT put a check mark in "DTS digital" If there is one there, uncheck it. That is what is screwing everybody up, that is a movie sound setting usually only found on high end music concert DVDs (like the Eagles) you will get no sound on some games and some regular movie DVDs with this setting selected. Move your screen right once more with your left joystick...click "save" and Voila!! Go start the game.
Jul 11, 2009 | Sony Playstation 3 (PS3) Console
Phone keeps restarting in 3 to 5 seconds .... also theres no light on the LCD
May be your cell have virus or your phone operating system is corrupt. Simply format your memory card and cell and problem still continues than go to nokia care they will reinstall your phone operating system.
Regards, Mohit
May 29, 2009 | Nokia 5310 Cellular Phone
My cell phone screen keeps on blinking
its just a problem with connections inside tighten up screws if you have knowledge in doing so...
Nov 24, 2008 | Nokia 6085 Cellular Phone
I can't get the internet connected to my laptop, it keeps disconneting, nothing is working.
have you check the modem connection of your laptop? check the setting of you internet connection first. thanks!
Apr 29, 2008 | Computers & Internet
Keep getting disconnectied
Look for a hardware update that you can download to your computer, then upload to your router. Other things you could try is unplugging the router overnight, pressing the reset button for 30 seconds, or setting it back to factory defaults in the settings. I hope this helps you.
Nov 05, 2007 | NetGear (GS608UK) 8x1000 Mbps Networking...
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
