Question about General Electric WSSH300G Front Load Washer
Ge WSSH300G0WW washer will not spin
We checked out the posts and saw that we should clean out the filter. we did not get much out of it and the washer still does not spin.
  • 121 Answers
SOURCE: GE WSSH300G0WW will not drain
this means the machine isnt spinning fast enough, or the drains are clogged.
Posted on Apr 29, 2009
  • 193 Answers
SOURCE: GE WSSH300G0WW will drain the water, but not strt
Yes, the filter can be accessed by removing lower front panel. Unscrew pump cover filter. Have a shallow pan and towels to catch water when servicing
Posted on Nov 14, 2009
SOURCE: GE WSSH300G0WW front load washer
WOW - I pulled out ton of lint and probably $5 in change. THANKS
Posted on Apr 08, 2010
SOURCE: my wssh300g0ww ge washer dose not do the final
I have the same problem. We have replaced the front memory board, checked for clogs, all the connections and still no luck. Did you ever find a solution? I am very fustrated.
Posted on Aug 19, 2010
walesarumi
  • 6993 Answers
SOURCE: my machine is not draining
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Take care.
Posted on Jan 11, 2011
I have a GE model wssh300g0ww washer and when I opened the washer the water was still in the washer and when I tried to have it stpin it made an awful loud noise and does not appear to do anything at all. ...
Hi, You need to inspect the filter. Its at the bottom in the front. Take a pan and place it under filter handle. Slowly turn it counterclockwise, water will start to come out. Empty pan when partly full. Repeat until no more water come out. Unscrew filter and remove. Clean, inspect cavity and replace. Hope this helps.
Jan 17, 2011 | GE Washing Machines
My machine is not draining properly GE WSSH300G0WW front load washer
Take care.
Jan 10, 2011 | General Electric WSSH300G Front Load...
My wssh300g0ww ge washer dose not do the final spin?
Jan 13, 2010 | GE Washing Machines
GE WSSH300G0WW will drain the water, but not strt the spinning. Is there a filter that might need cleaning?
Oct 11, 2009 | General Electric WSSH300G Front Load...
Apr 29, 2009 | GE WSXH208A Front Load Washer
My washer will not start!!
Does the start/pause button flash and then the door unlocks? I had that problem too. This is what I did. I found the solution to clean the lint filter on the GE Adora. Go to http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
I just did this and my washer is now running instead of the flashing start/pause and door unlocking. It was fairly easy. Make sure you have towels and a flat pan to catch the water if you don't have the machine on a riser. There may be water inside so a wet vac may be helpful too. Once my washer finishes what was in it, I have these funky towels to clean. You'll be very surprised what you find in the filter! Best of luck!
Oct 19, 2008 | GE WSXH208A Front Load Washer
Washer does not spin
I have a GE WSSH300G0WW washer and it is doing the same thing except I can not go to any other cycle to get it to spin. The water is just sitting in the machine right now.
Dec 12, 2007 | Washing Machines
Troubleshooting after cleaning out filter strainer
Do you hear if pump works or water coming out from the machine ?
Jul 23, 2007 | GE WBVH6240F Front Load Washer
General Electric WSSH300G Front Load Washer Logo
228 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
