Question about Psi Blue Max 2200 High Pressure Gas Power Washer
Pressure washer will not start
Was using pressure washer one afternoon shut it off to refuel and would not start up again.i cleaned plug carb and gas tank and coil and flywheel and still no go. so coil must be bad right?
  • 174 Answers
Do you get a spark? Take out the plug and leave the wire attached. Hold it close to the metal frame using INSULATED pliers. Have someone try to start it. Can you see a spark? Is the oil OK? Some engines have a low oil shut off.
Posted on Jul 20, 2009
I am completely stumped....Pressure Washer will not start I feel like I have tried everything. Please help
buy a new carburator on ebay for 20.00,the diaghram and all the rubber hoses are shot,that is what ethanol does,eiher try a rebuild kit or wait 2 days for a new one
May 07, 2015 | Cars & Trucks
Used my pressure washer last year. Tried to start it this year, will not start. Have tried starter fluid in carb, will only start with this for a few seconds. Replaced spark plug, checked oil. I am out of...
.This is in answer to no soap on the Karcher Factory-Reconditioned 2,600 PSI 2.3 GPM Gas Pressure Washer G 2600 VHR
Use the 65 degree low pressure nozzle for soap. The nozzle is black.
I missed it in the manual..drove me nuts until I slowed down to recheck the manual..
Aug 07, 2011 | Karcher G 2600 VH Gas Pressure Washer
My pressure washer sat for one year with gas and it wont start i added fresh gas and tried starting fluid it starts for a couple sec and shuts off...What should i do?
I hate to tell you but the carb will need cleaning. Try draining the bowl to get the old gas out.
Good Luck it is not that hard to do.
Feb 11, 2011 | Karcher 2500 PSI Pressure Washer
Starting problems
Sounds like jets are plugged in carb. Take off carb and take apart and spray with carb cleaner. Use jet tools and clean out jets, spray with cleaner real good then put back together. You may need to get a carb kit if gaskets are dry rotted.
May 02, 2010 | Briggs & Stratton Gas Pressure Washer...
Wont start acts like no spark but is getting spark
Did you try pulling the spark plug and spraying some starter fluid or carb cleaner into the cylinder, putting the spark plug back in and starting it? If you've got spark and it doesn't start for a few seconds then you probably have carb problems. Good luck!
Mar 06, 2010 | Karcher G3025OH Pressure Washer
Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Jul 18, 2009 | Honda 8 HP Engine
My Simpson Water Shotgun shuts down about a minute into the wash
Have you checked the oil level? Some engines have a sensor that shuts it down if the oil is too low
Jul 16, 2009 | Simpson PS2600 PowerShot Commercial-Duty...
Karcher 2400R
You have a poor signal to the spark plug usually caused by a rusty fly wheel found underneath the pullcord casing. clean it with releasing ajent such as wd 40. common when not in use for a while.
May 16, 2008 | Karcher 2500 PSI Pressure Washer
Psi Blue Max 2200 High Pressure Gas Power Washer Logo
271 people viewed this question
Top Psi Garden Experts
John Trevino
fordexpert
Jay Finke
Jay Finke
Are you a Psi Garden Expert? Answer questions, earn points and help others
