Question about Samsung DLP HL-P5663W 56" TV
Samsung model hl-r5667w ,big black box center of picture. I CAN NOT ERASER THAT BLACK BOX.
  • taeikchung41 Jul 21, 2009
    Iturn off caption function , then i can remove big black box on pic.
    President:
  • 3,278 Answers
Turn off the Closed Caption function. Hope this helps.
Posted on Jul 20, 2009
Samsung hl-r5667w DLP no picture,
Hello, are there any sounds coming from your television? If something happened to the colorwheel I dont think the TV would come on at all, I would by instinct take a look at replacing the DMD chip.
Jan 01, 2014 | Samsung HLR5667W 56" Rear Projection HDTV
I have a Mitsubishi projection tv model wd-52526. The tv has sound but no picture. It will display channels or devices Is there a simple fix to this?
no picture or a big black box covering the picture. If it is a big box covering the picture then you need to turn off closed captioning.
Mar 11, 2013 | Mitsubishi WD-52526 LCD TV
HI, MY TV PCL5415R, HAVE SOUND BUT NO PICTURES SHOW ONLY BIG BLACK SQUARE
Set would seem to be either in PIP (picture in picture multiple mode) or the black box might be the TEXT feature which is found in the closed caption menu.
Nov 04, 2012 | Samsung PCL5415R TV
Samsung DLP HL-R5667W not turning on. Showed
Purple spots means Bad Light Engine Part number is BP96-00822J Encompass Parts Has them for
$950.00 - $350.00 core price Part $600.00
1-800-638-3328 Lamp# BP96-01073A
Ballast Board# BP47-00027A
Jan 08, 2010 | Samsung HL-R5667W 56" HDTV
Samsung DLP turns on and off - cycle repeats
make sure put the lamp door back before trying to turn it on because they have switches on them that allow the tv to turn on. If that is ok you probably have a bad ballast.
Call a local tv repair shop to further diagnose the problem.
Dec 10, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-R5667W, seeing little boxes of static flashing
samsung color weel replacments are all the new air bearing type insted of fluid type. if you replace the new color weel , color will look bad. also note when ordering your replacment make shure it comes from samsung and not just a generic model.
the original replacement will come with a set of instroction to reset the dmv ajustments.
find the dmd pcb and look for a2 jumper that is visable through a small squaire remove the jumper. then folow instrustions with new color weel.
hope this helps.
regards,
daniel.
Jan 13, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HL-r5667w TV shuts down on its own.
You may have a colorwheel going bad. The bearings start going out and this is an indication of the failure. The colorwheel is located in the light engin e therefore you may want to get a qualified tech to look at it
Dec 16, 2008 | Samsung HL-R5667W 56" HDTV
Hl-r5667w
I just responded to your other post check the connection between the lamp and ballast at both ends. Also did you get the same exact lamp as your old lamp, as Samsung has two different arc gaps and they wont work if you get the other type even though they look the same physically.
Jun 21, 2008 | Samsung HL-R5677W 56" HDTV
Black box in center of the screen?
could it possible be a problem with closed caption setting....is this a square or rectangular box how big?
Feb 15, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Samsung DLP HL-P5663W 56" TV Logo
46 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
