Question about Tomtom One XL GPS Receiver
My power connector also broke off inside my GPS
Much to my husband's horror, I took my GPS apart to see where the connector needs to be reattached. So, after you soldered the piece, did your machine work? I don't have a soldering gun, so I might take the GPS to a TV/VCR repair shop...they should be able to make this repair for me, right?
  • 3 Answers
Hi - pretty sure you can take it to the manufacturer and see what they can do for you, too.
Posted on Jul 19, 2009
Key ignition broke my Husband took it apart and all these springs shot all over the place
You will need to replace the key cylinder and likely the ignition switch. Have done at dealer or reputable shop.
Nov 20, 2013 | 1984 Chrysler LeBaron
Tape strip came deattached
You can't. That strip is more or less a wire. You'll need to replace the whole laser assembly.
Nov 20, 2009 | Sony PlayStation 2 (PS2) Console
Loose part at the power input point.
it comes apart take out the 4 screws in the back. you'll need something to pry the back off .start on the side with something thin to unsnap the 2 halfs then use your fingers. after openning you'll need to resolder the powerport back on with a soldering iron and new solder. 4 spots hold the powerport on. it will be stronger than before. mine worked fine after.
May 03, 2009 | Magellan Maestro 4040 GPS Receiver
The HDMI connector broke loose from its mounting inside the tv.
It is possible for the HDMI connector to be re-soldered back on. However as the pin connections are small & delicate it is possible that some of the pads on the board may have been damaged, if this is the case then a new board would be required.
Feb 08, 2009 | Philips 52 In. LCD HDTV
Power adapter for Magellan 700 is broken
Connector J1 is the power connector. The left post corresponds to the center lug. The middle post is the outer connection. The right post closest to the USB connection is just an anchor - no connection.
Jan 04, 2009 | Magellan RoadMate 700 GPS Receiver
Opening the case to repair broken power connector
FIRST FAIR WARNING: This take apart is best left to the repair tech's at an authorized repair facility. There are 6 snaps, two on the top, two on the bottom and one on eash side. I used a thin blunt tip letter opener and started at the top. This didn't leave any marks on the case that would tip off the repair tech's that you goobered it up inside which you will do if you proceed! Release the two at the top first, then the two on the bottom. Now release the one on the side where the power button is located. Open the case on the power button side only about 1/4 inch and slide the bottom off the top being careful not to separate the power cord and headphone connector plugs from the board that they a fastened to inside the case. SECOND FAIR WARNING: It is very easy to pull the connector plugs from the board and this will really convince the repair tech's that you ruined your $350 GPS. Good luck and don't say I didn't warn you!!!!!!
May 13, 2008 | Magellan Maestro 4040 GPS Receiver
Delphi Nav200 gps problem
There are male and female tabs all around the plastic case of the GPS unit itself. Gently pry and push the case halves in and away from each other. Be careful not to lose your cool, as it is frustrating.
Mar 30, 2008 | Delphi NAV200 GPS Receiver
Power pin fell off inside of Magellan Roadmate 3000T
I managed to solder my connector back in place. The ground trace broke away from the board so I had to install a jumper to ground. I put RTV on the connector to secure it after the repair.
Worked great for a few weeks until it was dropped again and lost power, something else has a broken connection.
Jan 05, 2008 | Magellan RoadMate 3000T GPS Receiver
Tomtom One XL GPS Receiver Logo
132 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
