Question about Kenmore 63942 Dryer
Dryer wont start. I have went through the wiring but....
Nothing seems to be wrong there. I took the top back panel off where the start switch is located but not sure how to check if the switch is working. It seems like a pretty simple start switch but i didnt want to pull it off and not know how to check it. It worked yesterday and today nothing. Please give me some of you guys advice.
Thanks
Brad
    President:
  • 1,723 Answers
If it won't do 'anything' you need to check the whole start circuit. You need a multimeter and some knowledge of electrical troubleshooting to do this. I can help you if you meet the above description...let me know
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 20, 2009
TV repair?
You have to check the power supply board of the tv.if you wiah to know more details about how to repair flat panel television then check the following link
http://electro-medical.blogspot.com/
Aug 15, 2016 | Televison & Video
I have a Kenmore Elite dryer model #11087872602 that would not start or light up the panel on the front of the dryer. I had a general appliance repair man come out to look at it. He took both computer...
the start switch needs replaced, as far as the front panel light not lighting you will need to open the back top panel of the dryer and find the wiring diagram and trace it out, it may something as simple as the connector is unplugged. Hope this helps Tim
May 03, 2011 | Dryers
Light inside is on nothing else works
You will have to remove the back panel to access this part. Be sure that you unplug the machine before starting. Once the back panel has been taken off and placed aside the thermal switch will be located on the left lower side near the blower housing . It will be thin and long and located near the cycling thermostat that has for prongs on it. On certain machines, the thermal fuse is located in the front. To access this you must remove the kickplate, which can be done by pushing the clips, one on each side jsut above the top of the kickplate, in between the top and abottom portion. The part numbers are the same for either style dryer. To test this part you can either take the wires off it and tie them together then plug the machine back in and see if it starts, or you can use a multimeter and check to see if there is continuity, if there is its good, if not, bad. The thermal fuse will usually be white, and if located in the back, be thin and long with two wires on it, left and right. If in the bottom front, it will be front center on the exhaust duct. Another possible problem is that the door switch isn't functioning properly. You can visually check this by open the door and pressing the switch and listen for a click sound upon pressing and releasing .
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 30, 2010 | KitchenAid KEYS700LQ Electric Dryer
Yamaha r6 braking lights
Start with a new brake\tail bulb, then try unplugging the front brake switch on the handle bars , then try unplugging the rear brake switch. one of these options should locate a problem
Apr 22, 2010 | 2005 Yamaha YZF-R6
I have a Maytag Epic MED9700SQ 6 months out of warranty. I was using it when it quit working. Now when I try to turn it on every thing seems to be working. No error messages it seems to be working, timer...
You have a blown thermal fuse.
Unplug the unit.
Remove the top panel(two bolts in the rear metric 10 or Phillips will work) There are four screws across the top front of the control panel remove those and the panel will swing out and down,move it back and forth while pulling upward it has plastic clips on the bottom that keep it in place.follow the wires from the panel to the control board and unplug them or you can just lay the whole panel on top of the unit.
Open the dryer door and remove the two phillips screws on either side at the bottom of the door opening,then remove the four screws across the top of the panel it will lean out toward you,unplug the door/light switch and lift the front panel off the bottom clips.
You're probably looking for the thermal fuse located in the plastic elbow of the blower housing at the bottom of the unit it will be the round metal disc with a brown or black plastic backing.check your vent going outside and make sure it is completely clear/open doesn't have to be spotless clean but if it gets restricted in any manner it will blow this fuse.
Sep 13, 2009 | Washing Machines
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Ge microwave - making noise
I have a GE counter top microwave oven. When the oven starts cooking (the magnetron turns on) the oven makes a harsh buzzing noise. What is wrong and what should be done?
Mar 07, 2008 | Microwave Ovens
MAYTAG DRYER MDE5500AYW
Have you checked the door switch, thermal fuse on the heater housing(this will keep it from starting).
Oct 06, 2007 | Maytag Neptune MDE5500AY Electric Dryer
The light on top on my MRP-M450 blinks and the amp doesn't work
Well if you took off the cover on the amp and nothing seems to be burn't, check the voice coils on the sub. It's possible the voice coils have separated and is causing the amp to short it self out due to ground error. If that doesn't help let me know and I'll tell you the next step.
Sep 29, 2007 | Alpine MRP-M450 Car Audio Amplifier
Kenmore 63942 Dryer Logo
145 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
