Question about Panasonic Home Theater System System
I have the same problem
Only the front speakers are working, the surround suond is not. I have all good speakers. I have no output from the souround sound only. It seems as if my sub woofer is slightly lower as well.
  • 158 Answers
SWITCH THE PROLOGIC MODE ON
Posted on Aug 03, 2009
Denon receiver not working surround output
If everything is connected correct, the only thing I can think of, is you don't put in a surround signal. If you only feed 2 way stereo, only two speaker will work. Also if you switch to stereo, the other channels will stop working. Check the cables, the settings and the input.
Jun 15, 2014 | Pioneer VSX-D511 Receiver
Hello- I have my denon receiver connected to my tv with 2 front speaker,2 surround and center channel along with the sub. The problem is that when i play a blue ray, all my speakers produce sound including...
I need to know the quality of the speakers on the TV. Try unplugging it from the speakers on the TV and plug it into the souround sound speakers only and see if it plays differently. Double check your sourround sound and makes sure you did not reverse a wire.
DCBdigital.com
Feb 28, 2014 | Audio Players & Recorders
Only front and center speakers work, not surround.
If by white noise do you mean the test tone generated by the receiver? If so, this is actually pink noise and it is internally generated by the receiver. I would make sure either in the menu or on the remote that you haven't accidently turned off the surrounds and double check the wiring to the surrounds. Good luck.
Feb 15, 2010 | Aiwa AV-DV75
How do i put the surrround sound on my tv?
Depends on the complexity of your home theater system, but if you are just wanting to get sound from your tv to a generic souround sound, this is very simple. On the back of your tv, there is a audio output with 2 rca connectors. One is white and one is red. Also on the back of the sound system is the same colored inputs. Get the needed cable to connect the 2. You should have surround sound. Given you tv doesnt have audio outputs, your media player ( dvd, vcr, blue ray, sattelite) should have an audio output. Connect the electronic the same way as stated above.
Sep 10, 2009 | Durabrand 5.1 Surround Sound Computer...
One Connector not working on Durabrand SA-SP9 Surround Sound
you have to test electrical out put, maybe loose wire inside or blown component
Jul 06, 2009 | Durabrand 5.1 Surround Sound Computer...
No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
May 23, 2009 | Kenwood VR615 Receiver
Switch our tv to souround sound
Surround sound will come from the speakers from your surround system. So if you have it connected through HDMI 1 select that option from the source button on the remote control. If you have it connected through Scart 1 then select AV1 from the source button. It also best to turn the volume from the TV to minimum so that the sound only comes from the surround speakers.
Mar 23, 2009 | LG 47LG50 47 in. LCD HDTV
Durabrand Surround Sound Right Front No Output
Nevermind....I feel like an idiot, but I had the balance all the way to the left on the media program on my computer....
Mar 02, 2008 | Durabrand 5.1 Surround Sound Computer...
Ps3 Surround sound
ttttttttttttttttttttttttttttttt
Nov 22, 2007 | Sony Playstation 3 (PS3) Console
NO surround sound coming from our harmon/kardon speakers when set up to our onkyo tx-sr601 receiver. wires connected in correct areas, front left, right and center speakers work, subwoofer works. setup for...
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Jun 04, 2006 | Onkyo TX-SR601 Receiver
Panasonic Home Theater System System Logo
223 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
