Question about OKI C5800Ldn Led Printer
How do you reset the OKI c5800 drum?
I see on other printer fix sites its possible to reset the drum life on 5500s 9300s and many other okis but have not yet come across the solution for my c5800. Any help out there?
You don't need to go through all that mess of replacing the fuse. The tone gets everywhere and getting the Drum unit back together with all the gears and shafts lining up is a real pain.
The Drum reset system is very simple. When the printer powers up and runs through its system check, one of the tests energizes the erase LED array built into the Drum unit. The reset fuse routes a small amount of low voltage current off this LED array. There is a contact on the end of the Drum unit that the printer senses. It there is voltage there (ie the fuse is good), the printer resets that Drums counter to 100%. If there is no voltage (ie the fuse is blown), the printer continues on its way.
All you have to do it act like fuse at the instant the printer sends power to the LED array.
There's no soldering, no screws to undo, and no toner all over the place.
The best thing is it takes about 3 minutes start to finish and cost $0.00!
Here's what you need:
• A simple volt/amp meter (an analog one works best, but digital is fine also) • Two pieces of thin wire about 300mm long. I used old telco wire. With insulation, its about 1mm wide. • A pair of scissors to strip the wire ends • X-acto or thin razor knife
1) Strip about 4-5mm off the one end of each wire and 25mm off the other end. Bend the 5mm end at a 90 degree angle right at the base of the stripped part. 2) Pull out the Drum unit (leave the toner cartridge attached to the Drum unit) 3) On the right end of the Drum unit (DU) there are three square brass contacts about 3mm wide. The right end is the end with the blue handle. Looking at the end of the DU, you are interested in the 1st and 2nd contacts from the left (they are the two closest to the screws on a c5800 cartridge) 4) Use the X-acto knife to lift the contact metal and slide the 90 bent end of the wire under the contact. Do this with the other wire on contact #2. 5) Put a little vertical tension on the wires and route them around the blue toner release handle. 6) Gently insert the DU/toner cartridge into the printer. Keep slight tension on the wires until the unit is seated. 7) Wrap the 25mm stripped end of the wires around the volt meter leads. Wrap one so it makes electrical contact, but you could pull it apart instantly at the right time. 8) Set your voltmeter to the lowest amp setting. I put mine on 200micro amps. Also make sure your voltmeter leads are in the correct holes of the voltmeter. You want the amperage or milliAmp holes not the voltage holes. Don't forget to turn the meter on. 9) Get prepared to pull one of the leads off of the one of the thin wires and turn on the printer. Don't be afraid to touch the metal of the wire; the voltage/amperage supplied to the LED array is very low and will not hurt you. A 9 volt flashlight battery is more dangerous. 10) About 10 seconds into the startup routine, you will see you voltmeter display a reading. Instantly pull the leads apart.
Congratulations, you are now officially a 1/16amp fuse.
Your printer will reset the Drum Unit counter and you have another 20K impressions (if the image quality is acceptable to you)
If you have any question, just respond to this post. I'll get the email and answer you.
Good Luck.
Paul
Posted on May 22, 2010
  • 2 more comments
  • jennifer1989 Jan 13, 2011
    Hi Paul,
    I found your directions to be very concise, however I followed them for use on my C5500 toner and I was not successful if reseting my toner cartridge. I used a analog volt meter set on OHMS to x1K, I hooked it up as you directed and turned the power on and like you say within 10 seconds I seen a pulse of energy and I quickly removed the wire from one of the leads to my meter. It started to continue its start up process but then it read "Check Toner Cartridge/Toner Sensor Error 542C" I tried the process three more times including checking the leads and made sure I seated the drum properly, I received the same message each time.
    Any advice would be so much appreciated if you could direct me on what I could have done wrong.
  • john Feb 03, 2011
    I just completed this and it was super easy! Thank you for saving me 100 bucks.
  • sabidv Mar 23, 2011
    how did you do
    it does not work for me
    can you tel me steps
    sabidv@yahoo.com
  • REYNALDO DE LA PENA
    REYNALDO DE LA PENA May 29, 2011
    The instructions were great! i however did this without a meter just with timing counting approximatively 9-13 seconds at the start of ram check depending on which drum is being reset i went over a couple of times before getting it right, if you do the printer gives you a fatal error (dont worry!) just turn off and repeat the procedure i manage to reset Y,M,C drums to 100 my k drum is at 53% so i will ride this one out. Great info Paul best regards. Laredo Texas.
  • 22 Answers
C5800 is the same as the C5500. It is also fuse inside each drum cartridge that needs blowing in order to reset the drum counter. Only works when printer is in "Replace the drum unit" state.
Posted on Jul 27, 2009
OKI B410dn drum life
Every Oki B410d printer, Oki B410dn, Oki B430d, Oki B430dn, Oki B440dn, Oki MB460, Oki MB470, Oki MB480 are contacting the module of the Oki 43979002 drum and fuse with chip developed in the module imaging unit through joints being in the bottom part of a printer like in a photo. Eksploatacja Oki B410 pochodne drukarki reset kasowanie bbna
Jan 28, 2014 | Oki Electric Industry C8600n Led Printer
Message saying drum unit life on OKI PRINTER C510dn
This model OKI printer is not an inkjet printer, it is a color laser printer. and uses color toner cartridges.
The printer image drum unit has reached the end of its service life and this drum unit needs to be replaced.
I suggest you Google the Internet for an OKI image drum unit for your model printer, You will get various suppliers and their prices.
The image drum unit will cost approx. A$200
Feb 07, 2013 | OKI C5100n Laser Printer
Oki c5800 belt life reset
It may require a complete service kit, you should check with Okidata to see if there is a kit available or what steps you should take to reset the life counter.
Jan 29, 2013 | Oki Electric Industry Okidata C5500, C5800...
I HAVE C5500 OKI PRINTER AND THE ERROR SAYS REPLACE IMAGE DRUM 561:M DRUM LIFE I PUT IN NEW MAGELN AND STILL HAS THAT MESSAGE
oki printer c5950 fix new cartridge & drum coming error replace image drum 561:m drum life
Jan 15, 2013 | OKI C5500n Printer
My Oki C5800 says "Replace Belt, 355: Belt Life" but I was told I could reset it without changing it if it was still good. How?
requires a fuse that sits underneath the transfer belt. However the belt itself would be full of waste toner that would need to be emptied
Jun 30, 2010 | OKI C5800Ldn Led Printer
How to reset drum for the oki B410DN
Most of the OKI printers have a fuse installed in the drum to do the reset. If you google the drum reset kit you can find the drum kits and fuses.
Jan 14, 2010 | Office Equipment & Supplies
OKI C5800 ERROR MESSAGE- DRUM LIFE 10972
hi!!!
try to check the drum first!!!
clean it with the dry tissue?
there a lifespan of the drum
i have the same problem with that.
my drum capacity is only 30,000 copies
so then i replaced it! and works fine now
so try to replaced the drum it might on it capacity
or clean it
try to email me ronaldsuboc@gmail.com
Sep 18, 2008 | OKI Office Equipment & Supplies
OKI C5800Ldn Led Printer Logo
5,370 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
