Question about Hotpoint (HSM25IFTSA) Side by Side Refrigerator
Water Not Dispensing
My side-by-side makes ice but is not dispensing water
  • 6,784 Answers
HI, this is a defective dual water valve assembly. have this damaged inlet water valve device replaced asap, if possible.
Posted on Jul 19, 2009
My sixth sense side by side is dispensing water but not making ice
Need that model number to give you correct model numbers. Because you dispense water does not answer why you do not have Ice. The dual water control valve has two sides one or the dispenser and one for the Ice Maker. Does the ice maker have any water in the ice slots? Fill slots with tap water does it dump when frozen?
Appliance 911 Sea Breeze
Aug 01, 2015 | Refrigerators
Water dispenser has stopped dispensing water. I have a whirlpool 25.4 cu ft. Side by Side Refrigerator
there are a few things to check real quick
does your ice still work
does your ice make still work
when was the last time you changed the filter
when you do call for water can you hear the water solonoid
Nov 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My GE side by side fridge/freezer is working, water dispensing ok, but not making ice. I switch off the fridge, than ice maker but still not making ice. I try all the hints from Manual but no luck. Water...
fill the ice maker with water manually, if you have ice in the bucket you know that the ice maker is working , after check the water valve if is opening , if it is replace main board
Jun 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
Water despenser
The water dispensing valve may not be functioning, if the valve buzzes or hums when the water dispenser is pressed the valve may be mechanically deficient, if there is no sound whatsoever the switch for the dispenser,the dispensing valve coil or its electrical connections may have failed.
May 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker will not make ice
the ice maker is not making ice but the water is still working
Jan 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Oct 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hotpoint (HSM25IFTSA) Side by Side Refrigerator Logo
186 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
