Question about Sony Dual-Alarm AM/FM Clock Radio with Automatic Time Set
I need the colon in the time display of the Sony ICF-C1iPMK2 to stop flashing.
  • 3 Answers
Sometimes the colon is the 'seconds' count - did it always do this? Try to unplug for 1 minute and then reset the time - if it still flashes I suspect that it was a built in feature - some do this...
Posted on Jul 19, 2009
How to reset time
To set the clock, press
"Clock"
once
or
"Timer/Clock"
twice
(depending
on your keypad)
The colon symbol (:) will flash.
Enter time of day.
The time appears
in the window; the colon continues
to flash.
Press
"Clock"
or
"Timer/Clock"
again - colon stops flashing; time of
day is set !
Nov 16, 2015 | Panasonic Microwave Ovens
Setting the clock on a microwave what is the last action after setting the time. Everything I've tried results in the error message coming up.
According to the manual this is how to set clock.
To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
Enter time of day. The time appears in the window; the colon continues to flash.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
If you need the manual it is on link below.
http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
Good Luck
Nov 08, 2010 | Panasonic NNH965BF Microwave Oven
Sony ICF-C211 Clock Radio started to display minutes:seconds only instead of showing hours:minutes. I guess, I might have pressed certain combinaton of buttons to start this. Unfortunately, I do not know...
might not be the solution but similar happen me and i went back into time and after awhile found reset,so jus keep trying,if not,turn off unplug for 24 hours and it should flash all zeros when plugged back in,but make sure no batteries in it,lol
Jan 16, 2010 | Sony ICF-C211 Clock Radio
How do you set the clock
Clock setting procedure is written in user manual, click Sony Support to download a copy.
Plug unit in AC, display will flashing AM 12:00
Cress clock button for few seconds, unit will beeps and hours will start flashing.
Press tuner/track+time set +/- button to change hours, again press clock button to change minutes etc.
Hope this info will help you.
Nov 24, 2009 | Sony ICF-CD543RM Clock Radio
Use Sony ICF-C1IPMK2 in Europe
A transformer type (Linear Mode Power Supply) AC to DC power adapter with a 9.V nominal output, measures about 12.V without load when tested with a multimeter. A power adapter with a nominal output of 7.5 V, measures a little over 9.V. Considering a number of people across different forums reported the adapter's measured power output as 12.V, I think the nominal rating of the AC to DC adapter should be 9.V. However, keep away from Switch Mode Power Supplies.
Jul 21, 2009 | Sony ICF-C1IP White Powered Speaker System...
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
No Battery Power
Late with this answer.... Battery tabs sometimes loose contact with signal board near volume slide, possible solution is to reapply solder and bend contacts slightly.
Dec 01, 2007 | Sony ICF-SW77 AM/FM/SW Radio
Sony Dual-Alarm AM/FM Clock Radio with Automatic Time Set Logo
421 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
