Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Wont drain outherwise works fine
Wont drain
  • 6,784 Answers
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Posted on Jul 19, 2009
Do i have to drain when on air conditioner
Yes condensate will leak out outherwise
Jul 28, 2015 | Danby Heating & Cooling
Miele washing machine wont spin or drain
clean your filter first then check there is nothing in the pump area
Jan 22, 2014 | Miele Washing Machines
Lg waveforce wont drain
New drain pump may be needed
Oct 07, 2017 | LG Wave Series WT5070CW
My spin cycle on my maytag washing machine wont work. All else works fine but it wont drain or spin??? Please Help
check th elid switch to unit as it may have failed... it will stop the unit from going into a spin cycle and draining,,, give that a look and repost if you have anymore questions... good luck
Jan 09, 2011 | Maytag Atlantis MAV6451 Top Load Washer
Wont drain for spin cycle
in the previous statement i meant to say,if its plugged and cant drain then it wont advance to the spin cycle
Oct 16, 2010 | LG WM0642H Front Load
Whirlpool 4213632 wont drain water on perm press or delicate
check manual as this seems to be correct, Often called rinse hold or crease gaurd on many other machines
Feb 11, 2010 | Washing Machines
Washing machine wont drain or spin all other cycles work fine
you may have a timer problem just advanced your timer on click ahead when it happenes if it drains or spin replce your timer thanks from giles
Mar 14, 2009 | Washing Machines
Washer wont spin or drain
did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
Feb 07, 2009 | Frigidaire Washing Machines
1993 cutlass supreme
Are you Sure the Alternator is Fine???? Sounds an Awful Lot like it is not Charging the Battery to Full Capacity.
Jan 22, 2009 | 1993 Oldsmobile Cutlass Supreme
Remote
You should try E BAY' Eany sanyo vcr remote should work.
Outherwise call sanyo and ask for a remote.
last of all by a cheep sanyo vcr of EBAY.
Oct 05, 2008 | Sanyo VWM-800 VHS VCR
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
138 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
