My rca d52w20 turns on to a bright green screen for a few seconds then turns off, any ideas whats wrong and how to fix it? Chassis # is ATC221 if that helps.
  • 8,617 Answers
Green picture tube or the green CRT drive board is bad. You can get the replacement parts at the following link.
http://servicemanuals.vstore.ca/
Posted on Jul 20, 2009
D52W20 chassis ATC221 picture is fuzzy,blurred,unreadable.I do have a"convergence" option on the menu.have not done anything to the fuse fl231 yet.Will it help if replaced?The convergence does...
Yes - that may help if its done correctly...Sites like www.TvRepairKits.com have the parts and also parts with instructions to do it right the first time.
Aug 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA 52"
Yes the ATC221 uses the 259296 flyback. If audio works and the on screen menu also comes up but no video its most likely a vertical deflection issue. I would check the vertical IC for signs of bad solder.
Mar 29, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 ATC221 TV Schematics/Service Manual
go to www.tvrepairworld.com they can assist you and they have all the components for the RCA ATC and ITC series televisions and very knowledgable staff for RCA problems based on symptoms.
Apr 09, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" D52W20 ATC221 TV Problem
The FBT is dead.The buzzing sound mean there no high voltage is come to the CRT(tv tube).No burning,marks on the FBT doesn't mean it not dead.I change parts all the time with out burn marks on them.Trust me i replaced dozen of the FBT before.It make buzzing noise it dead.
Mar 16, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have an RCA D52W20 with chassis ATC 221 that no longer works. When plugged in, the green power light blinks twice and then goes out. When the power button is pushed the light blinks twice, then about 4...
The tv is going into protection shutdown. It will try to power up three times, but each time it tries, the microprocessor recognizes an overvoltage, or overcurrent draw, and after three attempts it will place the unit into protection shutdown. There can be many causes of this, but the most likely one is that there is a short circuit in the high voltage circuits. You probably have a shorted flyback and associated components.
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA D40W135D with ATC221. Will not come
Sounds like the HV splitter, Very common problem with that chassis
Nov 22, 2009 | RCA D52W19 52" Rear Projection Television
CONVERGENCE WILL NOT ADJUST ON SIDES
First you need to read the supply voltages to the STK's. Black things, size of 2 match books on a big heatsink. Sounds like your supply voltage is low, could be a bad STICK STK. usyually stk 130-20 or 150, etc..
Mar 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
No power
Check the ribbon cable connections between the boards to insure they are correctly seated as a 19 code usually means
Chassis detection, which means its not detecting a valid chassis usally the ribbon connections are the cause of that.
Jul 31, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
140 people viewed this question
Top Televison & Video Experts
Electro Med Services...
