Question about Gateway FPD2275W LCD Monitor
Monitor quit and won't come on again. Daewoo L510B1.
When I boot up, the monitor's green light comes on very briefly then goes to orange. The screen is dark without a picture, but appears to be backlit. It doesn't appear to be the computer since it works fine with a different monitor. I opened up the case and noticed a fuse. Could a blown fuse be the problem? Thanks.
  • Lynn Saville Jul 16, 2008
    I am having the same problem. As soon as I boot the computer on the monitor goes from green quickly to orange (standby). My mouse also won't bring it out of standby mode. When I hooke up to another computer they both work.
Posted on Aug 27, 2008
When computer off monitor displays orange light.when i turn computer on green light briefly on than goes out. Monitor remains black'
This is not always a problem with the monitor. It could also be caused by a faulty display card in your computer. Try plugging your monitor into a working computer to determine where the problem lies.
Best wishes,
Jun 08, 2010 | Computers & Internet
Monitor receiving signal, but no image
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
Monitor will appear to come on a "no signal" sign flashes up then the screen goes black. If you press the on off swich the green light will come on briefly then go to orange and then disappears completely...
could be a number of possibilities, lcd backlight is going bad, bad capacitors on the power board, lcd cable needs to be reseated, power board needs to be replaced. Best possibility would be to take it to a repair shop and see what the costs would run to fix it.
If its more then the cost of a new monitor then get a new monitor cause you would get the warranty.
Jun 28, 2009 | Westinghouse L1975NW Monitor
Viewsonic VG700b bug
The light turning to orange means the monitor is not getting a signal from the computer. Check your monitor cable at both ends and make sure it is in very tight and secure at the computer end as well. Also check to see if the computer stays on when the light goes to orange on the monitor. The power cord for the computer might be loose.
May 20, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Monitor has a hard time starting up
replace the "keyboard board" and the "power inverter board" (both boards)....
Oct 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
There is just no way you will be happy to hear it needs service or replacement under warranty.
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Gateway FPD2275W LCD Monitor Logo
94 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
