Question about Fedders AEQ07FBG Air Conditioner
Fedders my wall unit(a fedders) isn't blowing cold air
    Champion:
  • 233 Answers
If it is blowing at all, this narrows the field to a compressor issue, if the compressor is coming on, but not blowing cold it could be that the coils are dirty and need to be cleaned. They can appear clean from the outdside and be dirty on the inside.
Posted on Jul 20, 2009
Can a fedders air conditioner A7Y15F2A-E be recharged?
Hello, anytime the unit does not blow out cool air I like to start with checking the airflow, check the filter and the evaporator coil for a buildup of dirt. If that check out ok then either the unit has a refrigerant leak or the compressor is not operating if the compressor is running than the unit is low on refrigersnt and can be recharged. In order to recharge the unit a piercing valve must be installed on the low side of the system, most window units do not have valves so one must be added to be able to charge the unit.
Jun 29, 2012 | Fedders X Chassis A6X08F2A Air Conditioner
Air is cold but hardly blowing
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 21, 2011 | Fedders A6D24E7D Wall/Window Air...
The reset button that came on the cord of my Fedders model AED24E7F-C keeps tripping after a short while. Otherwise the unit blows cold and works fine. I can hit the off button when it is working fine...
Do you have anything else on the same circuit? I have heard about many of these units, not just Fedders, that will not run on a circuit that has another appliance or something that is pulling a lot of amperage. Also, check and make sure the receptacle is not worn and the plug is loose fitting. Other wise, you definitely could have a weak internal connection in the cord. Hope this helps.
Jun 28, 2011 | Fedders AED24E7F Wall/Window Air...
Fedders air conditioning model a3t12f2ag , my unit runs fine but it will not blow cool air?
you either have internal thermostat problems, selector switch problems or youve got a freon leak. to determine a freon leak is the units coil freezing up or is it dirty check filter first take unit out and to car wash remove housing and give it a bath dont plug it back in until its dry.hope this fix works if not work your switches remember they set in one position most all the time if freon call a tech
Jun 18, 2010 | Fedders A6D24E7D Wall/Window Air...
Compressor comes on, some cold air, no fan?
Try spinning fan by hand. If it spins freely, change capacitor. If fan is tight, change fan motor.
Apr 08, 2010 | Fedders AED24E7F Wall/Window Air...
Fedders wall air conditioner
If the compressor only turns on after the units it's shut off then it is a control board problem (stuck relay)
Jun 19, 2009 | Fedders AEY12F7F Wall/Window Air...
Heat doesn't work on ac
You need to check if the heat strip is still good on it or that it is receiving power. If its getting power, then the strip is bad.
Apr 01, 2009 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
Unit Does not blow cold air
compressor is not coming on or low on freon. Not something you can fix yourself.
Jun 10, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
Comp shuts off
Coils could be dirty. Compressor could be getting too hot and cutting off. Will have one fan motor that turns condenser fan and evaporator blower.
May 30, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
Fedders AEQ07FBG Air Conditioner Logo
213 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
