Question about Tecnik TKL9260 Front Load Washer
Washer wont drain
I have a wirlpool ultimate care II. it works fine except wont drain. what can i do ?
  • yadayada
    yadayada May 11, 2010
    unless you are very good at electronic testing call a repair person.
  • 6,784 Answers
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Posted on Jul 19, 2009
The Ultimate II washes clothes fine, and the water does drain, but the clothes are still wet after the spin cycle
see this causes and fix it. God bless you
Washer does not drain Again, depending on the brand, different parts should be checked. 1st check the lid switch. If you hear the machine trying to work but no water seems to be draining, you might have something stuck in your drain pump. You need to check the drain pump. Whirlpool & Kenmore direct drive systems use a mechanical pump attached to the front of the motor. Most other newer models use an electric drain pump except for some of the older Frigidaires, Maytags, Amanas, & Admirals, they have a belt driven pump. Check for clogs & belt conditions on these models.
Oct 11, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II Washer will not drain
bad lid switch,open the lid a few inches and close it down,if you do this a few times and don't hear a clicking sound the switch is bad.
http://www.youtube.com/watch?v=PZAbg9uftos
Jun 05, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a wirlpool ultimate care washer the drivecoupler is broke how do I know the tranny is good ? or is the tranny bad and this is what broke the coupler?
most of the time coupler will be fine. but it could be broke b/c of tranny. spin by hand make sure tranny will spin freely both ways. make sure it adjitates and spins. then replace coupler start it up. the good thing is that a coupler is cheap so if it ends up being bad you didnt spend much anyways.
Aug 01, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Tub won't drain
The lid switch has a green ground wire and 2 hot wires. Jump them 2 hot wires and see if she pumps out.7bce33c.jpg025e16d.gif
More here
bypass it here for testing purposes. How it works: direct drive washer
Jul 12, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Phillips Whirlpool Ultimate Care II won't spin very quickly
If this is a top loader it is possible that you have a bad clutch. sometime when your transmission leaks oil it will get into the clutch and this will cause a slower spin and possibly no spin. Tip the washer back just enough so you can see under the washer. Is there a orange/yellow sticky substance under there? If so this is trany fluid.
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Wont drain or spin
Check your lid switch it's probably broken.
Jul 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Barberboss
need more details please stopped what wont fill wont spin wont drain does it make any noise ?? does it fill and not wash
May 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Hey
the timer is the issue
Apr 11, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer won't start spin cycle
sounds like a lid assy issue, can you hear a "clicking" just before the lid is closed, try opening nad closing a few times listening for a distinct "click" if not the machine doesnt think the door is closed and for safety reasons wont spin and drain.
Mar 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Appliance rewiring wiring WIRLPOOL ULTIMATE CARE II
The Whirlpool Ultimate Care II cannot be outfitted for a standard 115 VAC wall outlet. Your dryer is a 220 VAC appliance. It needs to have it own dedicated 30 amp, 220 VAC circuit with the proper outlet and power cord installed. The dryer heating circuits and timer will not run on 115 VAC. I think you need to reconsider what you are about to do...
Jan 23, 2008 | Dryers
Tecnik TKL9260 Front Load Washer Logo
153 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
