Question about Philips Magnavox 55P9271 55" Rear Projection Television
Our Magnavox Model 55P8288 big screen TV shut off.
It will only stay on between 5 to 10 minutes and shuts off automatically.
It will sometimes turn back on right away and sometimes you have to wait a while.
4 Suggested Answers
Ecollier2012
  • 3459 Answers
SOURCE: Philips Magnavox 55P8288 Entire picture has green
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Apr 11, 2009
  • 73 Answers
SOURCE: my phillips magnavox big screen tv model number
Check the audio setting to make sure the internal speakers aren't turned off. Check to see if it's set to use external speakers. If it is setup to run sound through an av receiver check all connections, make sure the receiver is on the correct input setting, and speaker wires.
Posted on Jul 05, 2009
ladywinn
  • 5138 Answers
SOURCE: i have a hitachi big screen model 50ux22b after
Replace Both of your STK ICs they are big black IC example STK392-110s if 110s use 150s Call Mats For Parts 1-800-628-1118
Posted on Dec 15, 2009
Tv shut off on its own
Replaing the lamp will fix this problem most of the time.If not count the blinks. This is an error code.
Apr 01, 2010 | Sony Grand WEGA KDF-70XBR950 70" Rear...
My Magnavox digital converter box shuts itself off every 5 minute
Check that you have not got an auto power off setting on. Check that the aerial connections are good. That the signal is strong from the stations it is picking up. Weak signals can cause the box to shut down.
It the box is very hot when it shuts down, you might have a fault on it.
Apr 04, 2017 | Philips Magnavox M61117 (DBM61117)
I have a magnavox model 35R502-00AA help
you tv have a problem of vertical ic or cacacitor or resistor right around vertical section. that is make tv shut down in alot of magnavox tv. good luck!
Jul 27, 2009 | Televison & Video
My phillips magnavox big screen tv model number 55p8288 doesnt have any sound when i turn it on
Jul 05, 2009 | Philips Magnavox 55P9271 55" Rear...
Magnavox 55p8288 tv not turning on
My problem is the same as the other two ppl. The Tv does not come on only the power button keeps flashing on/off.
Nov 30, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips/Magnavox TV, model MS3250C321 shuts off randomly.
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Oct 17, 2008 | Televison & Video
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
55inch. magnavox projection tv. mod.55p8288
sell my the Lenticular Screen (the first screen) or find out what part you need and buy it from me.
danj34 [at] gmail [dot] com
Dec 02, 2007 | Televison & Video
TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Aug 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Open Questions:
Philips Magnavox 55P9271 55" Rear Projection Television Logo
316 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
