Question about Dell Inspiron 6400 Notebook
Replaced LCD Inverter, now screen comes on and bright but choppy
I have a Dell Inspiron 6400. The screen went blank. I hooked it up to an external monitor and a diagnostics test, claiming that the LCD inverter was bad. I replaced the LCD inverter, and the screen came on just fine, no problems. But after being on for a while, the screen started shaking and different colored lines strewn across the screen. Its all jumbled up. Now, it will only turn on every once in a while, work fine for a few minutes, get all screwey and then go black. Is the new LCD Inverter bad? or is something else the problem now?
  • Dell Master
  • 32,281 Answers
Does the external monitor display a normal image?
If the images is OK then the video card is OK.
The inverter supplies high voltage to the CCFL lamp which provides the backlighing and does not jumble the colors on the screen. If you get a pinkish hue or a flashing screen then this would indicate
the CCFL lamp is faulty.
From the description of the fault, it indicates that the fault could be a faulty video cable or video connector. Try reseating the video cable/connector on the motherboard.
Posted on Jul 20, 2009
I have a B130 that has a monitor problem. When I start the computer the screen flashes but will not stay on. It works fine hooked to an external monitor. I replaced the inverter. I was not paying close...
If the display works fine on external monitor your video circuitry on the motherboard is fine. Since you replaced the inverter brd and you still have the same problem it has to be either the LCD display panel or the LCD I/O cable or the connector on the motherboard that the LCD I/O cable plugs into.
Jul 24, 2011 | Dell Inspiron B130 Notebook
I cannot get the invertor off my dell inspiron laptop screen it seems to be welded on
The inverter is considered part of the LCD display panel and comes with it when replaced.
Jun 22, 2011 | Dell Inspiron 6400 Notebook
I HAVE INSPIRON 6400 LAPTOP. ON SWITCHING ON SCREEN SHOWS BLUE & ORANGE WORDING OF DELL LOGO AND THEN GOES BLANK. IT WORKS WHEN USING AN EXTERNAL MONITOR.
Run the LCD BIST Test
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=04&l=en&s=bsd&dn=1092705
If it passes, replace the motherboard, fails replace the LCD
May 17, 2010 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 - Screen visibility problems
This could be a faulty video cable or connector or CCFL lamp or inverter.
Try reseating the video cable/connector that connects to the motherboard first.
If this doesn't work then to determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 16, 2009 | Dell Inspiron 6400 Notebook
My Dell Inspirion6400 screen wont come on. I attached it to an external monitor, and it came up with the error code:0326 LCD Inverter Error, unable to turn lamp on. If I replace the LCD inverter, will...
Check out http://www.ccfldirect.com. they have a wide variety of inverters and backlight tubes for LCD panels and laptops. I'd change out the tubes at the same time you replace the inverter. The cost is minimal, and will increase the likelihood that you'll be successful
Jul 13, 2009 | Dell Inspiron 6400 Notebook
Replaced inspiron 6000 screen with 6400 screen
the screen is bad just look for something to do about it.
Jul 06, 2009 | Dell Inspiron 6000 Notebook
My Dell Inspiron 6400 is extremely dark. +brightness does nothing
Hi there.
Yes, if you can see a very faint image on the screen that indicates that the inverter or inverter coil has become defective and needs looking at or replacing.
Good luck and thanks for using Fixya!!
Feb 19, 2009 | Dell Inspiron 6400 Notebook
DELL inspiron 6400 laptop screen turned black
this sounds like a classic case of inverter problems, it could be just inverter coil thats gone which is an inexpensive repair, if it is the inverter then its a bit more.
try the Fn the F key that shows two tv screen icons, it may just have switched to external mode by accident
good luck
Nov 16, 2008 | Dell Inspiron 6400 Notebook
Dell notebook lcd scren
Make sure its not in hibernation,check brightness with darken and brighten buttons,does backlight work.Try hooking up external monitor and see if you get video.Other problems could be drivers.bad inverter card,LCD cable,LCD display,system board.
Mar 25, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 6400 Notebook Logo
444 people viewed this question
Alun Cox
