Question about Craftsman 25cc Gas Line Trimmer
Model #350795800 crafstman 432cc weedwacker. Same problem with the primer buld. Ficed that issue but now its too rich and fouls the plug. There is NO way to adjust the H@L screws as they dont have a slot for a scewdriver. Someone took off the plastic endcap that seals the H@L screws. Wgat size soket or type screw do I meed to make adjusement?
  • 3 Answers
Dump out the gas. With the ethanol added to the gas at gas stations, They are screwing up alot of lawn tools. You might has to get some dry gas and add it to your gasoline. Or try googling to find your answer.
Posted on Jul 20, 2009
Weedwacker has fire to the sparkplug and new gas to the primer bulb but will not start
sad these little gas engines always fail when we don't want them to . requires a lot of compression to run and if not properly oiled thru the gas will fail .
Aug 08, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
Craftsman weedwacker model #358797150 will not pick up fuel
Have you checked the fuel filter and made sure it is not plugged. Make sure the primer bulb is not cracked or leaking pressure. If you have then I would be sure the fuel cap is not bad. To check the cap you should be able to put the cap on the tank pump the primer button to build pressure in the tank and then turn the cap a turn or so and hear the pressure release. If that is all ok then I would think the diaphragm in the carb is bad and the carb needs to be rebuilt.
May 22, 2014 | Craftsman 29cc 4Cycle Straight Shaft...
Carbon fouling spark plugs
Weak Spark, worn piston rings(Burning oil/compression issues), lack of compression, wrong spark plugs, incorrect spark plug gap, engine not reaching operating temperature (Due to short use), carb. is running rich (May need adjusting), dirty air filter (Causing carb. to choke and run rich). Bad gas
All these symptoms could lead up to fouling plugs.
Hope This Helps.
Sep 27, 2013 | Garden
Tecumseh 5 hp snowblower carburetor adjustment
Having to run the engine with choke on indicates that there is an air leak somewhere in the fuel delivery. Check the gas line for cracks, and if your model has a primer, the hose from the primer to the carb may be cracked.
Dec 21, 2012 | Garden
I need a replacement head for my 25cc crafstman weedwacker gas line trimmer. I need the whole piece that screws into the bottom of the weed wacker. It is the whole part that spins when the wacker is...
You can find a complete trimmer head replacement at Hyperparts.com. Go into the Lookup By Application section and select the make and model of your trimmer to see a list of the heads they offer.
Jun 28, 2010 | Craftsman 25cc Gas Line Trimmer
Crafstman .25cc Weedwacker
clean the carburetor and clean the fuel filter.
May 02, 2010 | Craftsman 25cc Gas Line Trimmer
Fuel Lines - 25cc Craftman weedwacker
Your Craftsman Trimmer/weedwacker:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=358795591+&pathTaken=partSearch
Best Poulan Engine Match (probably real manufacturer):
http://www.ordertree.com/modelinfo/PWE/BC2400-Gas-Trimmer-Type-6/75.BC2400-Gas-Trimmer-Type-6.1.59.1.html
My decisions are being driven by my experience with Poulan chainsaws. Small hose in tank (long enough to reach all corners), filter on bottom, connects to lowest connection on carburetor. Small hose on upper carburetor connection to small fitting on primer. Large hose from large connection on primer through largest tank hole, roughly mid tank long. nothing on bottom. I suggest you leave the 2 connections on the carburetor long enough they can be swapped (just in case) then try it. if no go swap them.
Typical fuel system and a suggestion or two:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
This is how I would configure it if a chainsaw, doubtful they would do something completely different. In defense of Jerry, he knows how it should be done, clarity of instruction could use some help. Good Luck. HTH
Lou
Feb 24, 2010 | Craftsman 25cc Gas Line Trimmer
Troybilt weedwacker won't stay running. It starts
you may need to rebuild the carburetor.Check all the gas lines for cracks or leaks.Check the primer bulb if it has one.Then try and readjust the carburetor.If that still don't work,then try to rebuild the carburetor.
Sep 02, 2009 | Garden
Craftsman 25cc Gas Line Trimmer Logo
159 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
