Question about Symantec WinFax Pro for PC
Faxing Problems Hello, We are a 911 center that uses winfax to fax police and fire departments call sheets from our C.A.D system. We provide service for 56 departments. Of these departments there are 4 that we cannot fax to using winfax. We can fax to these departments using a regular fax machine in the dispatch room.  We have take a know (Working) fax machine to these locations and still experience the same problem. It appears the far end machine recognizes the incoming call but then terminates the call. We have forced it manually also without any luck. These locations are from different Central Offices.  I was wondering if the overall loop is too long.  Does winfax add any loss to the circuit. Gene Miketa Beaver County Emergency Services Center
  • 883 Answers
Does winfax add any loss to the circuit. No.
Try increasing the "time-out" setting. This terminates an attempt after waiting too long for handshake. It's been a while since I used Winfax, so I don't remember where that setting is located. However, it may possibly be done at Windows control panel. Look for the "printers and faxes" icon then select the advanced Tab and try different print spool options also.
Posted on Nov 20, 2007
It is not possible to email the scanned file directly through the printer. However, you may send fax over the Internet
You may subscribe to a low cost phone service that allows you to send and receive faxes with your device by using the Internet. This method is called Fax over Internet Protocol (FoIP). You probably use a FoIP service (provided by your telephone company) if you:
• Dial a special access code along with the fax number, or
• Have an IP converter box that connects to the Internet and provides analog phone ports for the fax connection.
NOTE: You can only send and receive faxes by connecting a phone cord to the port labeled "1-LINE" on the device. This means that your connection to the Internet must be done either through a converter box (which supplies regular analog phone jacks for fax connections) or your telephone company.
Some Internet faxing services do not work properly when the device is sending and receiving faxes at high speed (33600bps). If you experience problems sending and receiving faxes while using an Internet fax service, use a slower fax speed. You can do this by changing the Fax Speed setting from High (the default) to Medium. For information on changing this setting, see Set the fax speed. If you have questions about internet faxing, contact your internet faxing services
support department.
(Ref from the manual of the printer.)
Hope this helps.
Jan 23, 2010 | HP OfficeJet J4580 All-In-One Laser...
Cannot close controller to allow re-install of winfax pro 10.02
Control-Alt-Del and end tasks Wfxctl32.exe, wfxsvc.exe , wfxmod32 ...and faxmng32.exe
This can be any number of problems, like corrupt logs, too many entries in your default log structure,. You can check this link regarding rebuilding your logs:;CODE=01;HID=30
WinFax Tools has many fixes for WinFax that are automated.;f=17;t=412
Jan 09, 2009 | Symantec WinFax Pro for PC
Notification when fax arrives
In the 90s, cell phone companies and pager companies use to provide a seperate phone number answered by a computer that you could dial with your computer modem which would page/text a specific device you specified.
Most cell phone companies no longer offer this service.
WinFax/TalkWorks can notify your pager or cellular phone (using SMS messaging) whenever new faxes or voice messages arrive.
WinFax/TalkWorks works with Tone Only, Numeric, Personalized Numeric, and Alphanumeric pagers. To use the pager notification feature, you must know:
1.the capabilities of your pager/cellular phone
2. the telephone numbers WinFax/TalkWorks must dial to connect to your service provider
3. your personal identification number (if your pager supports this feature)
Sep 27, 2008 | Symantec WinFax Pro for PC
Broadcast Fax Sending
Change the resolution to STANDARD. This will cut your send times by 50%
Sep 06, 2008 | Symantec Winfax Pro 10.03 (winfax10.03)...
I can't send to certain fax machines with WinFax Pro
Yes, some modems might have problems with Service Pack 3. You might need to update the Windows modem drivers.
Alternatively, there might be problems with the settings in WinFax for your specific modem.
You'll need to post more information on the fax modem you are using.
Jul 28, 2008 | Symantec WinFax Pro for PC
WinFax Pro 10 setup problem
Go to "Control Panel", then "Regional and Language Options", then "languages", then "details", then "advanced", then click "turn off advanced text services". Also turn off Asian languages. Then you will be OK.
Feb 10, 2008 | Symantec WinFax Pro 10.0 for PC
Do not use a fax machine. It can only fax to one location. Instead, use a computer with a fax modem and a software tool such as WinFax to do your mass-faxing.
Jan 24, 2008 | Brother MFC 8500 All-In-One Laser Printer
Winfax pro suddenly faxing to wrong number
you have some options, so choose one.
  1. remove your fax
  2. configure your fax to answer later (maybe after ringing 10 times) and configure the winfax to answer before (something like ringing 5 times or less)
the problem here is that the fax answer and start receiving the fax and the winfax receive the fax signal at same time. check the winfax maybe you have the half part that the fax modem not has printed stored in winfax, maybe.
as I said, your better choice is removing the fax modem. even configuring like I said before, maybe the two continue to try to receive the fax at same time.
hope it helps.
Dec 13, 2007 | Symantec WinFax Pro for PC
Fax once,Received Twice?
It is mostly likely on your end. Sometimes if the line drops or for some reason the fax is interrupted it will resend the entire fax. I wouldn't worry about it unless it's faxing twice each time. If it is, check the settings closely in the software to be sure there isn't something strange set to send twice.
Mar 19, 2007 | Symantec WinFax Pro 10.0 for PC
Symantec WinFax Pro for PC Logo
125 people viewed this question
Top Symantec Computers & Internet Experts
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
