Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tractor has a very touchy clutch
I bought a new manual transmission 19.5 horsepower craftsman lawntractor this spring. In gears four or higher when you let off the clutch the mower jerks and will actually pop a wheelie. There is a possibility that this thing could flip and land on top of you. Is there anyway to adjust the clutch to keep from doing this?
  • 35 Answers
When you change the transmission, also change the drive belt?
One of the most often cause of transmission problems are the inadequate drive belt. The length should be the same as the manufacturer specification. Also the drive belt surface quality is very important. Keep in mind that the "clutch" is a simple mechanism that depends on the slipping belt feature and its right lenght. Frequenty users cange the belt and use an automotive type belt.
Let me know some news about your problem.
Have a grat day!
Fernando
Posted on Jul 19, 2009
I have just fitted a new transmission belt to my westwood 1012, it will go into gear when the motor is off but when the motor is running the gears will not engage when the clutch is pressed
You've probably put the belt on incorrectly or not put the clutch wheel or spring back correctly. When you press the clutch a jockey wheel on the drive belt should release the tension, allowing the belt to slip and the gears to be engaged.
Oct 28, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
Transmission will not engage.
The transmission belt is probably loose or the clutch is faulty.
Apr 29, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower has difficult time moving forward
Is the mower blades engaged if so check spindels if not check the transmisson but check all pulleys first
Sep 23, 2017 | Craftsman 20 Hp 42" Deck Lawn Tractor
Ihave a craftsman 20 horsepower riding lawn mower. It starts fine but it barely moves. It stops moving. Seems to have no power, especially if on a slight slope. I had a new clutch installed, but still...
Either your drive belt is loose or your transmission is going bad.
I would have another mechanic, not the one who installed your "new clutch" take a look at it.
Sep 27, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Hard to shift
Sounds like clutch needs adjustment. If you just bought it new, recommend you call store where purchased for help.
May 08, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman lawntractor model # 917273121
There is no tension adjustment it has an idler pulley working off from a spring. Check to make sure that the spring did not come off or break. If neither of these have happened then the belt is stretched and you need to purchase a new one.
Apr 12, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn tractor won't move when put into gear
First, check the tension of the drive belt. There should be an idler pulley which is spring loaded that creates the tension. When you push the clutch in, it will release the tension. Also, check to see if the rear wheel hubs have set screws which lock them onto the axle Make sure they are tight.
Aug 02, 2009 | Craftsman Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
496 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
