Question about Microsoft Xbox 360 Console
I got four red rings then it just shut off
It won't turn on any more so i took it apart and cleaned it out and it still won't work
  • 21 Answers
Hello-
If you have FOUR Red Rings on your XBOX, it means that you have a problem with your AV cable.
First, check the little switch on the AV cable. (it normally should be set to "TV" and not "HDTV")
Second, try swapping the AV cable with a known working one.
If that does not correct the problem, try cleaning the inside of the AV cable port on the back of the console.
As a final test, (if your XBOX and TV have the HDMI ports) try using the HDMI cable to see if the Red Ring goes away.
If that does not resolve the problem, please feel free to call us to discuss in more detail.
the GEEKsters
818.306.3012
info@theGEEKsters.com
Posted on Jul 19, 2009
My Xbox 360 red ringed about four days ago, so I hadn't turned it on since then. I took it home for spring break to try to fix the problem or whatever, but when I turned it on, it didn't give
They can be. If the console is not working properly the controllers usually dont turn on correctly. Try sending it to videogame911.com i used them for my red ring issue with my XBox and got it back within the week. Also they were EXTREMELY low on price compared to the manufacture and offered me a 90 day warranty with all data saved. Hopefully this works for you!
Mar 29, 2013 | Microsoft Xbox 360 Controller
It keeps spining will not stop
Air rachet? The valve probably got something in it and won't shut down the air flow. You will have to take the valve portion apart and clean it out. Look for any bad o-rings while you have it tore apart.
Feb 05, 2012 | Craftsman Professional 38 in Ratchet...
Hi, I had all four lights turn red then console shut down and won`t switch back on. Any idea`s?
red ring of death, its a software issue, have to replace your system, return it to where you bought it or to a local "gamestop" they will guide you from there
Dec 30, 2009 | Microsoft Xbox 360 Console
3 rings of death turned to 2 rings. xbox 360 NEED SUGGESTIONS
you probably did something to where you messed up your xbox motherboard, making it (after less then a minute of power) get short circuited and power fails. i would recommend getting it repaired by microsoft if you have a warranty.
Dec 03, 2009 | Microsoft Xbox 360 Console
3-red rings fixed, now 2-red rings...can't fix!
ya under the heat sinks there are spacer like washers replace them and i should solve your problem i own 7 of them
Nov 29, 2009 | Microsoft Xbox 360 Console
What can i do to fix my xbox 360 with 2 red rings
its simply overheated just take a wet cloth place on top of xbox and wrap the power supply in a wet cloth too (not soaking wet moist) Hope this Helps@!@
Nov 26, 2009 | Microsoft Xbox 360 Console
Xbox 360 red light four red lights on the front of console
Yes you can fix it. Four red lights on is an indication that the video cable is not plugged into the console. I suggest you check and see if the pins in the cable and unit are not damaged and the cable is fully in the AV port. If all is well, than borrow another cable from a friend and try it in your console or try yours in theirs.
Ron
Apr 30, 2009 | Microsoft Xbox 360 Elite Console - Black
My xbox 360 keeps on restarting on its own
about the only thing I can recomend is make sure all connections are tight inside,because the most common thing to cause random resets is if a cable is loose,and the vibration causes it to make intermittent connection,shorting out and resetting.
Feb 19, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
73 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
