Question about Video Game Consoles & Games
My 2year old playstation3 starts and runs for around 2min then freezers and turns off, once off u cant restart with the remotes
  • pdou_100 Jul 19, 2009
    yes the light did turn yellow thank you very much for the great advice
  • 6,784 Answers
HI, in most cases, this will be a overheating issue. During this overheating episode, you should notice the main power light turning yellow during or after the freeze.If this is the case, you will need to purchase a cooling mechanism asap. this will heel any further overheating issues in the future.
Now, if this is not happening, this is not an overheating issue and, it will confirm a more serious problem that concerns the Hard disk. In this case, you will need to have the damaged Hard Disk replaced. Due to the fact that Sony dose not allow consumer based sales of there internal Hard disk design, you will need to contact Sony for this hard Disk replacement procedure asap, if possible.
Posted on Jul 19, 2009
Computer restarts over and over @ bios screen
you may try resetting bios by taking off the small battery on motherboard for few sec, also if you got manual for your motherboard there may be way to reset bios sticking together 2 pins for couple of sec. Is radiator fan working? if no there's solution.
Feb 11, 2014 | Gigabyte GA-M68MT-S2, AM3, nForce 630a,...
Whirlpool top freezer 18c.ft w/ icemaker: freezer works fine. fridge does not cool below 56 degrees. vacuumed dust from bottom, turned entire unit off and restarted but still not working, in back of
i think you have to check to make sure that
the fan inside the freezer is cycling on.
it will be concealed of course but you should
be able to hear it. i replaced one once with
the same symptoms and that fixed fridge
portion of a 2002 or 3 whirlpool. make sure
to listen closely and not mistake it for the
stronger fan motor which operates in
conjunction with and nearby the compressor.
Feb 05, 2013 | Whirlpool Refrigerators
2year old G E ,freezer works , but fridge want cool , lights and digital controls are fine
Hi... you have a bad defrost element .. I bet the element is black ...
Mar 31, 2011 | Refrigerators
Stop 2min and run for 2min, stop 2min and run for
your motor thermal safety relay is protecting the motor from burning out
this is usually caused by: an old motor about to fail (tight shaft bearings) bad centrifical switch or, an obstruction in the water flow causing the motor to work too hard (draw too many amps, get too hot then cool down and, start up again
check the relay it is located on the side of the motor on most motors; under a cover; unless the motor is bad the relay may just be too sensitive (old) and, may need to be replaced.
Jul 24, 2010 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Looking at buying a 2000 s80 T6 and have a question...
Once the car is running and moving, the remote starter system is basically not an issue at this point. If there was a problem where immediatley when you put it into drive the car shut off, or something of those lines, i could see a remote start possibly being a cause. But if you were driving it, and went to turn around, and the car quit, i would not be suspecting a remote start system to be the cause.
Dec 15, 2008 | 2000 Volvo S80
Zannusi TCE7127W Not turning if load too heavy
It is very likely to be the condensur,or it is called a capacitor ,device for storing electric charge to boost the starting of the motor under load.in other words change it.UF will be wrote on it maybe 10 uf .I feel wasted on this site its so easy .
Nov 30, 2008 | Zanussi TC7102W Electric Dryer
Fridge not working
Normal machine 2 cycle,
1st.washing
2nd 'ON'
select the 'ON' Again compressor start with in 2min
Jul 05, 2008 | Refrigerators
Wont blow air
Sounds like the blower motor or capacitor has failed. Either part should be checked and replaced by a licensed contractor.
Jun 01, 2008 | Frigidaire FAC107P1A Wall/Window Air...
Hotpoint freezer
The compressor needs to cool off before it will restart. Leave it unpluged for a couple hours to see if it will restart.
Apr 04, 2008 | Freezers
Video Game Consoles & Games Logo
16 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
