SOURCE: Insignia® - 75W DVD/CD/HD Radio
Connecting an external AM antenna solved the problem. The internal antenna (if there is one) is useless.
SOURCE: How do I connect my
If you want to amplify the sound you will probably need an adapter. You will use the audio output jack on your computer to an input jack on your receiver. There are usually several different inputs on a receiver but most use RCA phono plugs. The best choice input jack one the receiver is the one that says "AUX". You can buy the adapter cord at any Radio Shack. You will need to be sure to ask for a 1/8 inch stereo phone plug to two RCA phono plugs. This will split the stereo signal into left and right channels for your receiver.
SOURCE: User Manual for Sony 2
http://www.sony.com.au/support/product/mhc-wz5
This is the closest I could find. Download from the above link (Open or Save)
SOURCE: I am looking for the
This may be a pretty difficult task - since it is very small and looks similar to the AM antenna jack. We might think we have found the FM plug, but when fitting to the radio, learn that it is really the AM plug.
You may do better contacting Acoustic Research to obtain an FM antenna replacement via their customer support webpage. The product information page devoted to your ARS2I lists no accessories available. You can freely view / download the manual for the ARS2I here if you need a copy.
I hope this helps & good luck! Please rate my reply. Thank you.
SOURCE: philips electronics company company knocksville
Dig around here:
http://www.p4c.philips.com/files/f/
Very slow to load initially.
