Question about Karcher K2.26 Electric Power Washer
Motor starts and stops
I have a karcher 3.86m electric pressure washer. when you turn on unit, motor cycles on and off. when you pull trigger unit works but at lower pressure.I've had it apart [ all of it] i see nothing wrong. I see the valve that turns machine on and off, when pressure goes up and down. but it looks ok. machine is older one, o rings are pretty soft still. but edges of rings look flat.
  • 174 Answers
Diagram here
It could be the Overpressure valve is leaking #20
It could be one of the small valves is not sealing #14 and #15
The soap valve could be not sealing #7
I have also seen micro cracks in the cylinder head #8
Good Luck
Posted on Jul 20, 2009
My Karcher 530M runs ok until I release the trigger, then it will not start again unless I switch and allow the water to run through for about 15 secs before switching on again
Hi Cliff:
My experience is that the pump pressures prevent the engine from starting, so we hold the trigger while starting.
My brother has cut a wedge of wood that he uses to jam the trigger open to bypass the problem. It can get a bit wild if the wand is not secured when the unit is started..
Aug 10, 2016 | Karcher Garden
What is this problem - Karcher 3.86 electric pressure washer: humming noise, plug gets very hot, then unit shuts down?
Your pressure washer is either not fitted with a run/stop device in which case like mine you have to switch off within a few seconds of closing the trigger. Check your model features?
The humming noise is the motor stalled out against the pump because there is nowhere for the water to go. The shutoff is caused by the safety overload switching off after overheat.
Or, it has a pressure operated run/stop which is not working. Because water and electricity don't mix, I would suggest getting more specific help. You can download Karcher manuals /spares lists online from Karcher specialists but remember electricity is the silent killer.
May 20, 2014 | Karcher Garden
My karcher pressure did turn on but stopped working altogether now wont turn on
Make sure that your circuit breaker did not go off and you have power..
Turn on the water after connecting the hoses. Then connect an ohm meter to the hot and ground legs of the male power plug. Push the on/off button to on and then pull the trigger. When you do that your ohm meter should indicate the resistance of the motor windings. If the resistance still stays at zero, then 1 - your motor is burnt out, 2 - the on/off switch is not working, 3 - the water pressure switch is electrically open. Check all three for proper operation and replace as needed.
Apr 01, 2014 | Karcher Garden
After sitting for several weeks, I plugged my electric 1500 PSI unit and nothing happened. Usually there is a pulse in the motor and it waits for the trigger to flow water to reinitialize the pump. ...
this Karcher unit have a termal overload in the motor but your problem can be cause by a pressure switch the shutt on and off the motor when you stop spraying.
Aug 15, 2010 | Karcher K2.26 Electric Power Washer
Karcher pressure washer hunts ~ off/on ~ when running. How do I fix?
HI Your machine wil start and stop if you have any external leaks when the machine is running at not pressing the trigger. Please start the machine and not pull the trigger and look form leaks. A common one is around the high pressure hose outlet and also the trigger.
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
Karcher K4.97M electric waterblaster cycling
It sounds to me like the unloader valve is bypassing internally.
Nov 16, 2009 | Karcher K2.26 Electric Power Washer
Cycles, never builds up full pressure when trigger pulled
If you are sure it is not a bad o-ring and you have re-assembled it correctly then try this.
Visit here:
http://www.rjbowers.com/parts_manuals/partslist_1190343804.pdf
Part # 8 in the pump, karcher # 9.001-187.0 includes a small bullet shaped valve. It could be leaking. It can be carefully disassembled and cleaned.
Jun 13, 2009 | Karcher K2.26 Electric Power Washer
Karcher K3.91 compressor run for a few seconds every 10-15 second
They have a problem. I removed both valves and lubed with lithium grease as I was told. Unit is now working for how long who knowes.
May 18, 2009 | Karcher PSI Electric Pressure Washer
Karcher k4.98 switching on and off
The machine has a pressure leak. Check for a cracked controll head or either a leaking outlet elbow. The machine will short cycle if the holding pressure can not be maintained
Feb 19, 2009 | Karcher K2.26 Electric Power Washer
Motor runs constantly with low pressure.
What you described I would think that it a switch problem, I would go to Karcher.com and order an original part for this and start over with the electrical portion and then go from there.
Jan 18, 2009 | Karcher K2.26 Electric Power Washer
Karcher K2.26 Electric Power Washer Logo
530 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
