Question about Cub Cadet Street Sign- tractor lawn riding mower parts
My 2166 Cub Cadet pops and backfires at high rpm.
It does fine at low idle but after you open the throttle up it starts to miss and backfire. I know this seems crazy but it seems to be a lot worse on an incline with the carburetor on the low side. I think it might be the Ignition module or the Speed advance module. Don't mind buying the right one to fix but don't want to buy both and only need one. Electrical parts are not returnable. Thanks a million if you can help me.
  • 22 Answers
Try replacing the air filter first or check it with the filter off, you may only need a new filter. if not get a mower or bike shop to test the coil they will let you which one to buy
Posted on Jul 20, 2009
Cub Cadet won't start and engine make a popping sound
popping is firing order not right or the timing has slipped.
Jul 02, 2017 | Cars & Trucks
My 87 savage will start fine, idle and rev at low rpm. but when I hit throttle it will backfire, pop, ****, etc?1 any ideas?
could be a bad valve intake side of headdoa compression test to make sure cylinders or reading above 100 lbs per cylinder
Dec 17, 2014 | 1987 Suzuki LS 650 Savage
Why does my Vintage Cub Cadet 125, Kohler 12HP engine pop/backfire and die when given any throttle?
Carburetor needs adjusted. May need rebuilt or just cleaned. Could be one of the jets is plugged.
Jul 19, 2014 | Cub Cadet Garden
Cub Cadet 2166 backfires when it gets hot.
powerwash the whole unit,make sure there is no build up on the head of the motor and all the fins around the motor,make sure that the heat deflector is installed properly,(Cub CadetKH-12-029-04
Adapter, Carburetor), #5,e09ec3f9-dc41-4345-8407-4807ef5e1296.gifalso be sure to clean the spindles and under the mower deck,also make sure the blades are sharp,grease all fittings,if the mower turns freely then there is less effort by the motor, 93d5c4db-8241-4eb5-94d5-cf708bb2f401.gif
here is the parts list for the mower,http://www.partstree.com/parts/?lc=cub_cadet&mn=2166+Tractor ,
May 21, 2014 | Cub Cadet Street Sign- tractor lawn riding...
I have a 1985 vt1100 c Honda shadow. It recently started idaling high by its self.I then removed tank and adjusted the idle and was fine for about 3 rides.Then it started idaling very low to actually...
Might be a throttle cable sticking. I would disconnect, from the throttle and drop some synthetic oil down the cable after finding some way to straighten it up and allow the oil to flow through the cable. It is an overnight operation and might actually take several applications.
As for the backfiring, I would question if you have carbs or fuel injections. If the later, you might be leaving your throttle open slightly and giving the bike fuel which pops off while changing gears.
Jul 20, 2017 | Motorcycles
Cub cudet 31p7770299e1 briggs stratton engine
only thing left is valve seat is loose and poping loose at a certain rpm causing backfire threw carb has to be intake valve
Apr 23, 2013 | Cub Cadet Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
1,511 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
