Question about Vacuums
Vacuum shuts off quickly...
The hose was blocked so Electolux Diplomat would shut off immdiately after turning it on. Solved that problem, unclogged the hose. Now, as soon as you limit the airflow slightly, it still shuts off. Any ideas ???
  • 97 Answers
Don't sucktion the hose or change the filter if it has one or the bag.
Posted on Jul 20, 2009
My rainbow stop working.no red lights.3 times try to start and then switch off by itself.what should I do?
PDF]3 - Rainbow
rainbowsystem.com/.../Rainbow_e2_2011_R14449A-1_English_P...
RexairAs part of Rexair's Customer Care program, each Rainbow and Power Nozzle receives a ... If the Rainbow is not working ... Do not clean the unit or unclog the hose until theRainbow is switched off and the plug is removed from the wall ..... alone or with the Jet Brush attached. ..... The Power Nozzle brush is stopped and.
My Rainbow Vacuum Cleaner Won't Turn On ' eHow
Rainbow keeps shutting off Vacuums Questions & Answers ...www.fixya.com > Forum > Tags > keeps shutting off > VacuumsRainbow vacuums keeps shutting off related questions and answers. ... My Rainbowstopped running I was using the Rainbow and it stopped running. ... the switch . my electrolux has the same problem but wont always turn on.so it probably is ...Three common problems with Power Nozzles and how to fix ...
Dec 03, 2015 | Rainbow Vacuums
I have an Electolux Diplomat that is about 25 years old. A friend recently fixed the switch for me but now the cleaner is blowing instead of sucking. Hose is on correct end. How do I reverse it?
Withould opening your device it's not possible to tell you what's the problem.
Guess you should call your friend or atake it to a repair service to check your vacuum but it's quite probable you should start thinking in getting a new one.
Oct 19, 2015 | Vacuums
What do the symbols and dial settings mean on the electrolux diplomat lx
Symbols..Question mark means "Put a bag in me", checkered light means : "Change me, I'm dirty"....pre-lit power light means: "You have Powaaa" to the unit and the thermostat light means the motor is too hot if it comes on, (most likely from a hose clog) and needs to cool down before the motor will run again. The settings on the control valve basically have to do with the auto shutoff when the bag needs changed. The lower the valve is turned, the more full the bag will get until it shuts off. Hope that helps!
Apr 24, 2014 | Electrolux UltraLux 2000 Bagged Canister...
Electolux vavumn overheats shuts off
usually caused by a stressed out motor..... clean the hell out of it... hose, filters .... everything...there could even be crud down in the motor itself... which requires taking the vac apart and pulling out the motor...dont be afraid to take hoses off and wash them out and dry them before putting them back on.
Nov 09, 2013 | Vacuums
The vacum will run until the hose is inserted and then the motor shuts off. The vacum switch must be hooked up incorrectly. Do you have a schematic?
Before trying to take it apart, check the hose for a blockage. Disconnect the hose at both ends, drop a coin in one end, lift that end of hose allowing coin to drop through. If it doesn't come through, there's a clog. You should be able to clear it by plugging the hose into the exhaust port of the vacuum, holding the other end to the in port, and turning on.
Another possible problem is a dirty afterfilter. Remove the air diffuser/tool holder on the back of the vacuum. If the filter is dirty, it blocks the air flow and the vacuum will shut off due to overheating. Remove it, connect the hose, and turn on the vacuum.
If you don't have a manual, you can download it at the below site. Click on the space under "older models", click on Ambassador III, and download.
Information for removing the air diffuser is on page 9.
http://www.aerusvacuums.com/support/manuals/
Feb 13, 2011 | Electrolux C101 Bagged Canister Vacuum
I have an older electolux vacuum. It says Epic
Vacuum either has a clog or full bag that is overheating the vacuum causing the thermal switch to shut it down.
Hope this helps.
Aug 14, 2009 | Electrolux Vacuums
Vacuum shut off
The motor gets hot when airway is blocked. Check your filter for debris deep in the pleats, clean it out, also check the hose for blockage.
Apr 04, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Dirt Devil Extreme Quick Vac - Won't turn on
Check that the filters are completely clear and not blocked - especially the top filter on top of the bin assembly. If its clogged completely brush it free of dirt and then reassemble. Make sure the inner cone filter and mesh filter is also completely clean. Then check the hose and main dust channel - something is clogged that makes this machine overheat and stop working - and often with this model (Hoover also make it in the UK under the Alyx name) its down to clogged filters or small clogs of dust in the dust channels.
Don't forget to rate, thanks.
Mar 06, 2009 | Vacuums
How do I unclog a bissell vaccum? I'm not just talking about unclogging the hose, I need to unclog the complete vacuum cleaner. HELP!!!
Well firstly, whats the model number and do you have the user manual to hand?
If the main hose has been unblocked, then it could be the main dirt channel which is blocked just after the moving roller brush panel. A long pipe cleaner or wire brush can remove this blockage easily rather than taking everything apart.
Apr 18, 2008 | Vacuums
Vacuums Logo
100 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
