Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
Suspect the bulb has gone out on my fireplace logs .
Is it a part i could buy in a hardware store?
  • magaskhosh Oct 14, 2009
    my pyromaster hef33 electric fireplace turns on with heat, but the heat element turns off after a few seconds. the fan keeps running. sometimes the heat comes back after several minutes for a short bit. the flames don't work either.
    Problem Solver:
  • 7 Answers
Yes - bubs are 120vac with a small base - not the standard light bulb type - more like the larger outdoor Christmas lights. There are 3 bulbs required. I'd consider going with the compact flourescent - they give off less heat.
Posted on Oct 04, 2009
How do I replace bulbs on model DS5603 Mod G electric fireplace
Do you need to replace the upper or lower light bulbs?
For both, first open the door of the fireplace. For the upper light, locate the upper bulb bracket (above the door). Bend the bracket down. Unscrew the old bulb and replace it with 7 W clear chandelier or candelabra bulb with an E12 base. Bend the bracket back up to its original position. Close the door, if only the upper bulb is out.
You will need a Phillips blade screwdriver to replace lower bulbs. Open the door (if it wasn't already open). Locate the screw that holds the log set in the center of the ember bed. Remove that screw and the log set. Locate the bulbs that are behind the log set and determine if one or both bulbs need to be replaced. Unscrew the bulb(s) to be replaced. Screw in the replacement 60 W clear chandelier or candelabra bulb with the E12 base. Replace the log set and press firmly against the glass. Replace the screw that holds the log set. Close the fireplace door.
The procedure to replace the bulbs is on page 4 of the service manual. It is also on pages 10-11 of the Owner's Manual. The documentation is available from Dimplex: http://www.dimplex.com/en/customer_support/technical_and_troubleshooting . The direct link to the service manual is http://www.dimplex.com/cms/publications/7400650000R04.pdf . The Owner's manual is here: http://www.dimplex.com/cms/publications/7206570100R09.pdf .
I hope this helps.
Jan 12, 2017 | Heating & Cooling
Our fireplace is 22 years old and we are not able to start the fireplace.
Is this a flame effect electric fireplace with a fan heater underneath it?
If it is, the bulb has gone. Remove the coal or logs and remove the cover. You will see the bulb.
Dec 29, 2015 | Heating & Cooling
What is the replacement bulb on a ADL2000m-x?
It looks to be a 40 watt bulb. Take the old one to the store and get one that looks like it with 40 watt rating.
Nov 12, 2014 | Heat Surge Accent Electric Fireplace -...
Muskoka electric fireplace ,the switch doesnt work
  • Unplug the fireplace
  • Open up the fireplace to gain access to the inside.
  • Inspect switch for charring, melting, etc.
  • Inspect circuit board for charring etc.
  • If indeed the switch is the culprit: then...
  • Unhook the wires from the switch.
  • Remove the switch.
  • Bring the switch into your local hardware store or radio shack.
  • Buy a compatible switch - pay attention to amperage markings etc. so your new switch can handle the power.
  • Install new switch and re-hook up the wiring.
  • Close up the fireplace and enjoy...
Nov 25, 2012 | Heating & Cooling
Light for flame went out. How do I replace it?
Remove the firebox glass (actually it's plexiglass) and set off to the side out of the way. Now, Remove the logs from simulated burner and set off to the side out of the way. The glowing coal effect plastic panel under where the logs were, should lift out, exposing the 60 watt, small base, chandelier bulbs, They unscrew counterclockwise from their individual holders. Replace the bulbs and reinstall everything else in reverse order, from the way you took it out. Caution: Be sure the Master On/Off Switch for the fireplace is in the OFF position, before starting any work on the fireplace.
Hope this helps you to solve the problem.
Apr 15, 2011 | Leisure HOMEPRIDE Electric Fireplace...
The light has gone out on my dimplex ASP20 fire.
There are several light bulbs that create the flame effect. However, it's unusual for all to go bad at one time. If you still have your Owners Manual, it will tell and show you how to access and change the bulbs. In the meantime, turn the Master ON/OFF switch to OFF and Unplug the unit from the wall outlet. Wait 12 to 15 minutes and plug the unit back in. Turn ON the Master ON/OFF switch and test each function one at a time. Hopefully, the time unplugged gave the unit time enough to reset itself. However, if this continues to occur on a regular basis, contact Dimplex USA, Technical Service at
888-346-7539
If you want to Troubleshoot and access the bulbs yourself: Remove the Plexiglas from the front of the fireplace and carefully remove the logs. The ember bed below where the logs were sitting will lift out and you'll have complete access to the bulbs. The bulbs are 60 watt, small base, chandlier bulbs.
Hope this helps you solve the problem
Mar 21, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
The light bulb keeps blowing out. Have the wires or socket gone bad and can that be replaced?
Remove the bulb and look closely inside the socket. If you see any evidence of burning or that it has been hot, replace the light socket. You can buy a replacement that will work at most any hardware store.
Feb 04, 2011 | Kenmore 51041 Kitchen Hood
I have an electric fire place. The blower is fine, however, the light that ulluminates the logs and makes it look like a real fireplace is out. How can I fix it?
I just repaired ours and it is quite simple,if it is the same type.First remove the front cover frame, then with a screw driver repove the clip at the top of glass,ease out the glass and lift up to remove.Remove the plastic logs and you look inside and you will see your burnt out lights,remove them, buy the same type and replace them, normally they are standard candleobra light that you can buy at any hardware store.
Nov 05, 2010 | Leisure HOMEPRIDE Electric Fireplace...
The bulb has gone on my microwave. How do I change
take the screws out of the cover take it off can now access the light-check appliance store or hardware for the bulb.
Dec 22, 2009 | LG LRMM1430 Microwave Oven
Flickering lights have stopped working
basically, on the bottom of the fireplace, there are 2 screws on the sides, 3 on the back, take them off, lift bottom (it wont come off, so be careful not to bend it) there are 3 christmas light type bulbs, you can find them at any hardware store. Just replace them. Problem solved.
Jun 18, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
116 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
