Question about Sanyo DP32746 32 in. LCD Television
Sanyo HT30746 When I push power button, tv turns on, sound works, but there isn't a picture. The screen will show a white/gray box for a brief moment and go black. Moments later the TV will turn itself off again.
maklean
  • 1665 Answers
SOURCE: sanyo vizon tv black screen
Have a look at link .Type in your model to see if a service manual is available.
https://www.manualsparadise.com/MainSearch.do?brand=312&model=15a&elementChanged=Find&registerButton.x=34&registerButton.y=4
Posted on May 24, 2008
javswr
  • 44 Answers
SOURCE: sanyo ce32ldy1b lcd 160gb black screen with sound
It sounds like you have a power supply problem, this powers the inverter! Where you just replaced the inverter, we could assume it is good! Look for some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain). The power supply can fail on some output and be good on others. Was the back light inverter new? If all else fails, see if you can return the back light inverter and get another! I hope this is helpful!!
Posted on Mar 02, 2009
  • 8457 Answers
SOURCE: Sanyo 42" LCD will not turn on!!!
Power supply board is dead.Buy a refurbish power supply board at Shopjimmy.com,Ebay.com for the replacement.
Posted on Mar 26, 2010
  • 8457 Answers
SOURCE: We were watching TV and the TV just turned itself
Yes,unplug,replug the tv an hour later.The tv should reset itself back to factory setting and work.Not,than the tv power supply board have problems.That the board,where the power a/c coard plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Oct 07, 2010
budmrtn
  • 11361 Answers
SOURCE: DP46849 has black screen with power light on.
It may be in safety shut down mode due to shorted circuits or power supply failure due to such thing as bad DC filter caps. You will need to do in-depth troubleshooting.
See www.shopjimmy.com if he has the picture of the boards.
Please read my guides also.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Mar 23, 2011
I have a Sanyo DP42841 I cannot adjust the screen size. When I try to adjust with PIX SHAPE I can get the big screen 4 but all the others are a box with gray bars on both sides. Interestingly enough
Roger, you might try this.. on some TV's it works. while it is unplugged push the power button on the TV and hold it in for 30 seconds or more. sometimes this Resets the tv back to Default setting. Hope this helps besides even if it doesn't work you haven't hurt anything or lost anything..
Jan 27, 2015 | Sanyo Televison & Video
No picture on screen
Is the TV under warranty? If it is don't muck around, contact them straight away as you have a electronic problem with your screen.
Before that make sure the yellow chord is in the visual port and red and white into sound. 2) If thats all good try an experiment, as you know the sound is good, use one of the sound cables to replace the yellow. Is there a picture now? If so replace chord, if not make contact to exchange for warranty.
Sep 02, 2012 | X2Gen MV32T8 32 in. LCD Television
When I turn on the TV by pushing the att button and power button
I need t know your fault conditon. If you are not getting the picture bu the sound then your screen voltage is very high showing this white screen. Check the crt base for failure and replace very carefully with a similiar type.
Jun 29, 2010 | Televison & Video
Black box covers most of the tv screen.
Just use the remote to turn off the closed captioning,The button should be marked as CC or you can just go into the menu and turn it off.
Jun 02, 2009 | JVC Televison & Video
Gray screen with horizontal lines accross it
sounds like you may have a bad ic it probley is a surface mount on the bottom of the board it could couse this problem would need to take to a shop to repair. The ic probley is numbered ic101 on board.
Mar 01, 2009 | Sanyo DS32224 TV
Sanyo DS24425 TV Has No Picture and Very Faint Audio
DONT BUY SANYO ELECTRONICS THEY ARE JUNK
Jan 09, 2008 | Sanyo DS24425 24" TV
Model; P52750WK serial; 340486076
Hit remote power button. Brief " crackling " sound, no picture. No problem with TV since new. There is a brief spark like light with sound.
Nov 21, 2006 | RCA P52771AT 52" Rear Projection...
Sanyo DP32746 32 in. LCD Television Logo
106 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
