Question about Hoover Vacuums
How do i change the belt on a hoover model #U4509
  • James Weber
    James Weber Mar 08, 2017
    Remove the two Phillips head screws from the bottom. Using a screw driver, pry the two clips holding the 'beater cover' in place and remove it. This exposes the brush assembly. Next there are slots along the outside of upper case where it meets the motor cover assembly, basically one in each corner. Use the slots to separate the top from the motor assembly using a screw driver as a pry bar. You now have access to the motor shaft. Remove the brush bar and wrap the belt around the brush bar assembly. Then stretch the belt back to go over the motor shaft to complete the belt replacement. Re-install the top cover on the motor assembly
    Re-install the two screws that screw the motor assembly to the top cover. Then re-install the brush assembly cover and you are done.
  • Hoover Master
  • 1,510 Answers
Lay the unplugged vacuum upside down and remove the bottom plate covering the brushroll to remove the brushroll and belt. Make sure brushroll bristles aren't worn, replace it also if needed. Make sure brushroll will spin freely. Put new belt around motor shaft then around brushroll. Pull on brushroll with both hands to get enough leverage to stretch the belt far enough to drop the brushroll in place. Put bottom plate back on and insure brushroll will turn by hand before you turn it back on..
Posted on Mar 11, 2017
3 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: hoover sweeper model U4263-930 belt change
undo screws on bottom of vac take out brush and belt put belt in then manewver brush in
thank you for useing fixya please rate me
Posted on Feb 12, 2009
fixdat22
  • 34 Answers
SOURCE: how do i change belt on my hoover sweeper
get a fillipshead screwdriver, put the vacuum facing you so the brush is infront of you, you will see 4 screws on each corner.unscrew those and when you do there will be a space where you will see a shaft that points out. take the old belt off and put one part of the new belt on the shaft and the other part on the brush near the belt. (there will be a little brown part on the brush for the belt to lay on) make sure its secure and screw the screws back and your ready to go !
Posted on Sep 12, 2009
Why does my hoover belt keep snapping?
Hello! Your belt will need to be replaced about twice a year. If your belt is breaking within a couple uses of you changing it, you may not have the correct belt for your vacuum. Double check the owner's manual or Hoover.com to verify the belt number for your vacuum. Always replace the belt with a genuine Hoover belt. Hope this helped!
Aug 25, 2014 | Hoover Vacuums
How do you replace the belt on a Hoover steam vac V Model 7425-900 ?
sdHi pdjanusz,
Does yours have a belt on it to change? The Hoover V models have air driven brushes. Can you tell me the problem you're having? Ar the brushes not turning?
Thanks,
Handie andie
Apr 11, 2011 | Hoover Vacuums
Belt change for model #u4258-930
This link will take you to a site with instructionsand illustrations to help you change your belt.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps
Jan 22, 2010 | Hoover Runabout U50-940 Bagged Upright...
How to change a belt on a Hoover wind tunnel
It depends largely on the model. Do you know the model number? you can get any hoover replacement belt here:
Replacement Hoover Vacuum Belts
Dec 09, 2009 | Vacuums
HOW DO YOU REPLACE THE BELT ON A HOOVER US140-900 WIDEPATH TEMPO VAC
To help you in your efforts to change your belt here are some good resources. This is the manual for your vacuum. It explains how to change the belt:
Manual for HOOVER U5140-900 WIDEPATH TEMPO VAC
Here you can get replacement belts for your models:
http://www.vacbelts.com/hoover-40201160-belt.htm
Oct 20, 2009 | Hoover S1410 WindTunnel Porta Power Bagged...
Hi I have model u64330-900 hoover windtunnel. It
It sounds like your vacuums belt is stretched and worn. You'll need to replace it. Below is a link to a website that gives instructions with pictures on how to change the belt. You should be able to get a replacement belt at any department store or vacuum retailer.
I hope this helps you.
http://www.info-vacuum-cleaner.com/hoover-vac-belt.php
Sep 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Change belts on a Hoover Power Drive Wind Tunnel Series 900 vacuum
Try calling Hoover directly toll free at
1-800-944-9200 M-F 8 AM - 7 PM EST.
Sep 08, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover sweeper model U4263-930 belt change
Feb 07, 2009 | Hoover Vacuums
Hoover F5914 SteamVac Deep Cleaner
There is no belt on this model. what is your exact problem?
Nov 06, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Vacuums Logo
63 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
