I turnd the set on and I couldn't see any swelling cap heads. Also the caps I replaced were not getting hot. However there was a ticking sound of some sort about 2 seconds before the set shut off. And the power supply didn't seem to be hot either.
  • 5,807 Answers
if you have a multimeter measure the voltage on the capacitor after the diode of chopper secondary windings.that would be the B+.
maybe the supply rail B+ is only about 45V or still lower
solution : replace the horizontal deflection flyback transformer maybe partially shorted
maybe no voltage at all
solution : check horizontal output transistor might be defective, replace if found shorted
maybe there is a good supply say at least 110V , but no oscillator drive on the horizontal output transistor, or blocked oscillator signal drive
hope this helps, thanks for using Fixya!
Posted on Jul 19, 2009
Visio VX32L has a black screen, appears to power on but picture.
Any swelling on a cap is bad sometime you wont see swelling ontop sometimes its on the bottom, I suggest replacing those caps then try again make sure you discharge the caps as well.
Also make sure its the right caps too!
1000uf 6.3volts or something like that. Ebay a good source for caps and amazon.
Dec 15, 2015 | Televison & Video
03 beetle 2.0L.new waterpump and thermostat hardly any heat.return line going to bottle has no cooland comming out.the steel fiting on the side of the head seems blocked..is there a check valve in it
Turn on the heat in the car to full heat an full fan. Remove radiator cap start car and continue to fill overflow bottle/tank until heater starts to blow warm that's when the thermostat begins to open. Keep an eye on matter level -make sure it's full. Replace cap a wait 6/7minutes open cap slowly and with rag and gloves it will be hot. Slowly -continue to add more water. Until full. Replace cap. Shut off motor and wait until it cools about 45 minutes. Remove cap again and add water as needed. Then run
Motor making sure it is full. One more thing most important anytime filling radiator always turn heat on first. If not you will ruin your radiator as they don't swell open they swell closed as to not let water move thru it's internal passages.
Apr 02, 2015 | Volkswagen Beetle Cars & Trucks
Ticking & white smoke after replaced intake gasket
Sounds like coolant getting into the combustion chamber. Potential causes in order of significance: Intake manifold gasket (might not have been done right), Head gasket(s), cracked cylinder head, or, cracked engine block. Check the oil. If it looks like chocolate milk it means the coolant and oil are mixing
Dec 30, 2013 | 1998 Chevrolet Astro Van
When you run the van the radiator cap does not get hot
Sounds like a cracked head or blown head gasket
Mar 02, 2013 | 1998 Oldsmobile Silhouette
98 chevy cavalier...water is boiling out of the overflow lid...it is plastic and that is where the radiator cap is. car runs hot, and water is gone when i get home...15 min commute. fill it up and...
sounds like it's time to take it to the shop and change head gasket if head is still good ! every time it gets hot it warps it, prob. need new head too !
Nov 11, 2012 | 1998 Chevrolet Cavalier
My lower radiator hose swells and engine overheats. 1998 Eldorado..with radiator cap off coolant shoots out like a gyser. Is this a clogged radiator
Sounds very much like head gasket or cracked head. You need to have a cylinder leakage test done by a mechanic. To hard for me to teach in writing.
Jun 28, 2012 | Cars & Trucks
My car (2003 Malibu) is overheating. The thermostat, water pump, and radiator cap has been replaced, yet it continues to overheat. What would you recommend be done next?
Check for blown head gaskets. GM aluminum-head engines are VERY UNFORGIVING when it comes to being overheated. The heads usually warp, resulting in blown head gaskets and repeated overheating like you are describing. One of the main symptoms will be that you fill the cooling system and open the bleader screws to get the air out of the system. Then you start the engine and run it until the cooling fan comes on. When the fan comes on, place your hand behind the cooling fan and see if the air coming through the radiator is HOT. If it is blowing cool air, the coolant is not flowing through the radiator like it should. This is usually caused by high pressure in the cooling system due to combustion gasses getting in.
Sep 05, 2011 | 2003 Chevrolet Malibu
Turned it off on the set...can't turn it back on...power button keeps blinkling red
The electrolytic capacitors in the power supply become damaged by heat.The top of the caps will swell up lookinglike a bubble instead of being flat they will needreplacement.the caps should be replaced with high temp caps.This is a commen problem with these sets
Feb 18, 2010 | Niko SV-3706 37 in. LCD Television
My 96 Isuzu Rodeo does not indicate that it is overheating but the hoses connecting to the radiator swell up and look like they are ready to pop. Now, there is a really loud noise like a metal fan hitting...
sounds like you might have a head or head gasket problem, combustion pressure leaking into radiator/cooling system causing pressure build up (hose swelling) the noise could also be from this failure.
get engine warm so hoses swell, turn off engine remove spark plugs leave radiator cap on and pressure from cooling system as is(hoses swollen) wait 5-10 minutes crank over engine with plugs removed and keep clear of spark plug holes, put paper in front of spark plug holes if water comes out of spark plug hole or slight wetting of paper with water head or head gasket is at fault.
Jun 13, 2009 | 1996 Isuzu Rodeo
1999 FORD ESCORT ZX2 radiator hoses swell and burst
you've got a serious overheating issue creating the pressure. Your temp gauge must be reading hot too.
If not, then you have engine compression pressure getting into the cooling system through a blown head gasket.
Replacing the cap will not help.
Mar 12, 2009 | 2001 Ford Escort ZX2
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
