Olympus FE-140 Digital Camera Logo
Posted on Jul 19, 2009
Broken clip on batterycover
A small piecce of plastic that secures the battery door has broken off. Can this be repaired
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 12, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
456
Points
Keep it shut with Scotch tape.
2helpful
My 1998 toyota corolla drivers door will not open fro the inside. pulled the handle out and it does not seem broken. what could be the problem
there is a wire rod from the handle to the door lock that is held in the lock by a small plastic clip. These clips break and the rod falls out. Repair is to remove the door trim put the rod back in using a new clip.
Hi I keep having the same problem with my land rover discovery series I, for some reason a little piece of plastic inside the door handle keeps breaking I've already replaced it once and now its broken...
I am guessing that the plastic bit is what holds the wire /rod in the hole of the lock lever It is a common connection piece in lock manufacture. If that is the case the piece that breaks is the bit that clips around the rod section(the clip fingers break off). Two fixes spring to mind is to use a piece of small wire (paper clip ) reposition the clip and tie to rod ( small zip tie may be easier) or 2 there are metal clips that do the same job( Mazda early models use these) but you could possible get them from a panel repair shop
1helpful
Camera Kodak DC3200 Battery door has clips broken. Where can I get it repaired in Australia and what is the cost of this repair, please?
Please check the link below and find the shop close to your place.
Also if the door has broken on the plastic side , you can use instant glue to bond after cleaning the surface and keeping the joints under pressure. Also you can wedge some steel ribs into the plastic to reinforce and glue on top, use soldering iron to heat the steel leads.
Battery door retaining lugs broken,also the plastic lugs on the main body that the battery door needs to latch onto are broken off ,cannot use camera as unable to secure batteries in the camera ,door will...
KODAK doesn't sell battery doors for any of their models.
A repair for this fault is 24,47 pounds + shipping to the repair centre.
If you already have the battery door; I suggest you will have a local camera TECH to attach the door to the unit.
2answers
Battery door latch broken
Unfortunately HP will not sell you a camera battery door. If you can find another camera that is broken with a good battery door you may have a chance.
To repair/transfer the new battery door, you will have to use a small jewerly store screw driver that you can buy at the dollar store and use it to push the door hinge bar to one side of the camera.
Then, pull the door hinge out but be careful not to lose the tiny spring that is installed in between the hinges. ( Make sure that you know and understand how to put it back the same way.) You can then pull the battery door from the camera.
Do the same thing to good camera. Practice on the broken camera first. The second time it should go easier for you. When you install the new battery door, push the hinge bar in all the way to one side of the camera. Hold the door to give you the proper alignment and then use the small screw driver to pry the hindge bar from the one side to make sure that it is equally in each of the black hinge connectors.
This worked for me. I was fortunate enough to find someone who had a broken HP MZ67 digital camera that had a "good" battery door. It took me about 30 minutes to complete the job. I hope this will help you. You can email me if you need more advice. I am a computer tech.
Steve ([email protected]).
1991 corolla door rod handle plastic clip broken
You can get inside door handle either new or used from sellers on ebay. It should be just a few dollars plus shipping. Just search ebay for "Inside door handle 1991 Toyota Corolla."
Frank
Frank's Friendly Cars Maui Car Rental
www.MauiCarRental.biz
Nikon Cool Pix 7900 Battery door won't stay closes
There are plastic clips on the battery door and body of the camera that lock the door in place. If they are broken of the battery door the door can be changed. If the clips on the body are broken the camera as a rule is history. Replacing a camera body is not a feasible repair.
Jul 02, 2009 • Cameras
2003 chevy impala broken handle
raise the window.
remove door pannel and water shield.
remove the plastic clips that secures the lock cylinder to the latch rod.
slide the lock cylinder clip out of engagement and remove lock cylinder from the door
disengage the plastic clip that secures the outside handle to latch rod.
remove bolts
then pull it out of door
1helpful
Battery Door Lock Clips Broken
this is a Fufi problem not yours, even if its out of warranty you will not be charged top have it repaired.
Broken door
Tape it shut is the only solution here No Spares no Repairs.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
