Garmin Nuvi 660 GPS Receiver Logo
Posted on Jul 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Garmin Nuvi 660 cannot acquire satellites
Stuck saying "acquiring satellites" but never does. The last time I did this I uploaded a new update and after many tried it did finally reboot, and has worked fine for about two months....now it is starting again.
NUVI 660
Anonymous
Level 2:
Sniper:
  • Expert 71 Answers
  • Posted on Jul 20, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
71
Questions
Helped
59303
Points
299
Hi I had this problem and its an antenna fault, give garmin a call and see if yours is still under warranty, if it is they will tell you to take it back to the retailor who will call garmin for a RA Number and they will replace it there and then. If your warranty has run out then call garmin to ask about repairs
Best Of Luck
4answers
Nuvi 660 cannot acquire sattelites
do a proper reset like take the battery out if its optional then press the power button for 30 seconds without connecting the power,if that doent help then you need to reset the software to the factory setting thorugh the menu itself.
Jul 04, 2008 • GPS
4helpful
2answers
The touch screenon my Garmin Nuvi 600/650 won't work. What can i do?
This is a common problem with units having the serial numbers beginning with "14V", "12P" and "143". It's caused by a defective SHARP touchscreen and needs to be replaced. Please see this link for more info:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Not able to acquire satellite. Garmin stays on
The flip-up internal antenna/GPS receiver is defective and needs repaired/replaced. Please see this link fo rmore info:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
3helpful
I have had a Garmin Nuvi 660 for 2 years now. While travelling in Florida last week with the unit on my dash and working properly I encountered heavy cloud cover. The unit said something like "poor...
if you havent gotten the December 2008 update for your 660, install the update and try again..this is a common problem with the nuvi series. you can get your update here
its near the bottom of the page.
Jul 24, 2009 • GPS
My nuvi 660 all it says is acquiring satellites
Try reuptdating your GPS or reset it it might be a bad patch.
Acquiring satellites
my friend has the same unit his will only acquire satellites when unit is plugged in the cigarrette lighter
2helpful
2answers
Dont Aquire Satellites
Ditto.. even after updating FW...
3answers
Trouble acquiring satellites
Garmin nuvi
will not acquire satellites
Garmin Nuvi takes a long time to Acquire satellite
No. 98% of the time it took 45-56 seonds for your NUVI 660. Thats the compagny set up time acquisition and it did very well.
Be sur you had your flip antenna parallel to earth surface.
660 has THE BEST SIRF Chipset for acquiring satellite.
I had 2 NUVI 660 since 2 years. It work much better than those new 7xx series who it really took 2-3 minutes to acquire satellite.
Be sure you update your version to the last one.
----> https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=134&pID=400
Best regards
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
