Question about Craftsman 8.50 Torque Rating Dual Rotating Tine Tiller
Tiller will go into every gear except forward/till..whats going on?
    Scholar:
  • 138 Answers
Check the shift lever where it goes into the transmission. a lot of times, the lever will get sloppy where the roll pin goes through and it won't shift into till. sometimes you can drive the roll pin out, pull off the lever and peen the holes over. sometimes you have to drill the lever and shaft and put in a snug fitting bolt and nut. OR, the chain driving the tines is broken, and that means a new transmission. hope it's simple
Posted on Aug 21, 2009
Transmission will not come out of reverse
what year is it does it have Belt Driven or chain drive ? do you put it gear with lever does it have handle to put it in gear ?is ther something stuck on the blades ? does it turn either Way ?
May 26, 2014 | Garden
Craftsman rear tine tiller
If you cant move the tines by hand then I wouldn't think you sheared the pins, more like a gear box problem.
Mar 21, 2014 | Craftsman Garden
I need the service manual for the drive train of tiller 21a-430-062
Please ineed your help,i cant play zynga poker the problem i traveled from lebanon to lagos nigeria so help me please to find solution thank you liliana daabul.
Dec 02, 2012 | Garden
Husqvarna 700DRT won't change gears
hello, you need parts or a whole new trans,and try and not het any more rocks,,
Feb 11, 2012 | Garden
The Tinds will not engage and I have problem getting the tiller in forward/reverse gear.
you need grease on your power shaft that has the forward/reverse this is where the power goes to the wheels slids back and forth A round wheel one side forward the other side reverse
Mar 24, 2011 | Yard Machines Tiller 208cc 18in Tilling...
I have a huskee garden tiller that won't till. It will go forward and reverse but will not till. I'm sure it has to do with the gears but can't find any parts manuals or information on the gear box. the...
I have experienced the same problem. Mine has set unused for a couple of years. I rebuilt the carb and got it running again, only to find the tiller/tine drive is locked up. I plan to disassemble the housing this weekend. When I find out what the issue is, I will post it for you.
Dec 15, 2010 | Mtd Garden
PTO making noise when engaged in forward drive
It's 90 weight gear oil but most likely the output shaft seal has been gone for a consdierable amount of time and has leaked out and is just now making noise, they don't normally make noise right away after the oil runs out. put oil up to the plug fill hole and watch if it runs out the shaft seal if it does then it will have ti be repaiered.
Nov 13, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Tiller tines won't turn where put in gear.
The spring goes in first followed by the ball. The ball should not get in the key way because that is filled by the slider pins that go up into the spur gear that drives the tines. Actually the slider pins drive all of the gears by engaging different gears as the gear collar is moved up and down. The detent spring and ball is the mechanism that is supposed to hold the the clutch collar in place. Mine jumps out of gear when tilling any depth except very shallow. I have reinforced the shifting forks and replaced the pins on the end of it. I believe that the pins wear and the arms spread because i have to keep pressure on the shifting rod or it will jump out of gear when tilling. Even with the reinforcing, pressure on the shifting rod will wear out the pins on the shifting arm. This will be my 3rd reassembly and I am leaning toward the detent spring being weak and allowing the shifting collar to move too easily. I may order an new spring and ball and see if that helps. I am getting pretty good at taking it apart.
Mar 18, 2009 | Mtd Bronco Rear Tine Tiller
Craftsman 8.50 Torque Rating  Dual Rotating Tine Tiller Logo
218 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
