Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Duel blades on craftsman riding mower cut unevenly
I have a model 917.255430 riding craftsman mower.  After cutting the lawn, there are lines in the lawn and it is obvious that one or both blades are cutting at an angle rather than straight across.  There is a strip of higher grass left after cutting.  I thought it might be because blades needed sharpening but the problem still exists after sharpening.  If the blades are not level, how do I fix?
  • barrysndi Jul 22, 2009
    Thanks for the help. The tires did need inflating and the problem is about 90% solved. There still are some indications that the blades are not cutting completely evenly butI am happy with the results.
Its not the tires it is the blades don't line up.One blade is three-quarters of an inch lower.Is there a shim for the star fitting.
Posted on Jun 11, 2010
  • 32 Answers
Check the front tire air pressures then for a bent blade
Posted on Jul 20, 2009
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
Craftsman 1000 lawn tractor, very uneven cut
behind the plastic covers on the side of the tractor part there is adjustment nuts
Sep 15, 2012 | Garden
Cuts uneven, lawn looks terrible. Missing half
Are your blades upside down? Mower deck level?Proper air pressure all 4 tires?Correct blades for the diameter of cut? Deck bent? Deck hangers bent?
May 28, 2010 | Garden
Unevan cut duel blades adjust deck
If the mower has been cutting fine in the past, and you do not see anything loose on the deck between the deck and the chassis. I would check the air pressure in each tire.
HTH
Good Day.
Oct 30, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Uneven grass cutting
I have seen dull blades, blades not installed right and an un-level deck cause that.
Hope this helps.
Sep 21, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cuts lawn uneven, one side shorter than other
Was it cutting uneven before you changed blades? If so, you may not have gotten the blade on the shaft correctly. There is an adjustment in the center of the deck hanger on each side. You can turn the 9/16 nut up or down on each side to level it out.
May 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42 inch riding lawn mower is not cutting evenly
The first thing to check is your blades. If one is bent, it will never cut even. It happens a lot hitting roots, antbeds, etc. Mulching blades will bend easier than a straight blade. It's best to take them off and lay one on top of the other to see if they're bent.
May 25, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
1,746 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
