Question about T-Mobile Sidekick® 3 Cellular Phone
Sidekick not charging
I have a sidekick 3 and when the battery runs low and charge it fir long periods of time like over night for example and its still not charging.
    President:
  • 625 Answers
The Sidekick 3 has a charging issue thatcrops up after awhile. It will just not charge the battery.A good way to tell is if the orange light comes on but the phone never charges.
YOu can get an external battery charger for the sidekick for about 25 dollars that will allow you to charge the sidekick 3 battery separate.
Check out the following link to see what I am talking about.
Sidekick 3 external battery charging cradle
Posted on Jul 28, 2009
  • 33 Answers
Do you mean like the orange light is not light up when
it were charging, correct? if so, then you need to get a new charger.
your charger is probably dead and no longer working.
if you want ,i have a brand new charger that i do not need(bec, i have
few of them laid around and need to get rid of it) and will selling
it for pretty cheap.
so let me know.
Posted on Jul 25, 2009
Can get it to chanrge (this is brand new)
remove the back cover and make sure the battery is inserted properly
Jan 10, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick won't turn on
If it is a sidekick 3, then the charging port has gone bad.
It runs about 80 dollars to get fix at cellulardr but can do a workaround for about 30.
You will need to get a charging cradle that has spare battery slot. See the link below:
Sidekick 3 Battery charger
I also recommemd a spare battery so you can have one charging.
Sidekick 3 Battery
Nov 27, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick wont charge
wakesk8er02
The sidekick 3 has a known issue with the charging port going bad. The orange light will usually come on but it doesn't charge the battery.
you can try www.cellulardr.com or you can do a work around that will cost less.
Most people will buy a cradle charge that has a built in spare battery charging slot. This allows you to charge the battery seprate form the phone. ?It is about 25 dollars on ebay. Its also a good idea to get a spare battery so you can have one charging at all times.
Sidekick 3 Spare Battery Charger
Sidekick 3 Batteries
Jul 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick 3
Maybe it's battery. Try to use another maybe helps.
If not it's problem with software in it, what is connected with power point-battery and its showing low battery and switching off.
Second what you can do is to clean connection inside maybe it's stuck something and not giving the power in.
Jun 12, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Ayy
Is the orange light coming on but you have no power? If so, then it is probably not charging. The sidekick 3 charging port is notorious for going bad. The little contacts that send power to battery come loose.
Find a friend that has a sidekick 3 or sidekick ID and try out their battery. If it powers up, it is your charging port.
The easiest thing to do is to get a charging cradle that has a spare battery charging slot. They run about 25 dollars off off ebay and allows you to charge the battery seperate from the phone. A spare battery is good too as it allows you to have one charging at all times.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Sidekick Spare Batteries
Jun 07, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick3
The sidekick 3 has an issue with thte charging port. If you have a friend with a sidekick 3 or sidekick ID, try one of their batteries. If your unit powers on, the charging port has gone bad.
the repair for a charginf port runs about 80-100 dollars. A cheaper work around is to get a charging cradle that has a spare battery charger slot. They run about 30 dollars on ebay and it will allow you to charge the bettery seperate from the phone.
Check out the following link for cradles.
Mar 29, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick wont turn on
Sounds like you unit is not charging. The Sidekicks are notorious for that. If you have a friend that has a sidekick ID or Sidekick 3, see if you can try their battery to make sure you phone is working.
If not, your best option is to get an external charger that has a spare battery slot That way you can charge the battery outside the phone! They run about 25-30 dollars on ebay and since you have an extra battery you can have one charging all of the time!
http://www.repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Mar 12, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 does not receive charge
All right. The Sidekick 3 has a known charging issue that crops up on some phones. If you are under warranty, call t-mobile and get it fixed. If not, the repair is going to run 100+ to fix the charging port.
A fast and simple solution is to by an external charger and an extra battery. They run about 30 bucks total on ebay.
Check out Sidekick Battery Chargers.
Be glad the battery is easily removable. The original sidekick and sidekick II had internal batteries that are a pain in the butt to remove!!!
Nov 07, 2007 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick® 3 Cellular Phone Logo
231 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
