Question about Kenmore Washing Machines
Noisy kenmore front load 44072 and it won't spin
    Sergeant:
  • 187 Answers
FOR NOISE
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
FOR NOT SPINNING
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
pls rate my suggestion......
Posted on Jul 20, 2009
Kenmore 417-48102701 front end loader washer. Won't go into spin cycle? Any thoughts of what to look for?
could be a number of problems,but try this FIRST push and hold any two buttons in for about 20 seconds make sure the machine is on,if this fails then you could have a blocked pump ie a sock is the usual suspect some mackines have a filter at the lower front check below the door if there is one then open and unscrew anty clock wise,if not then the pump will need removed and unblocked.adrianxxx
Jul 24, 2012 | Kenmore 44072 Front Load Washer
Where is the filter on my Kenmore 44072 washer?
you have a sock or simler item stuck in you pump .adrianxxx
Jun 19, 2012 | Kenmore 44072 Front Load Washer
My kenmore front load washer doesn't want to start all lights are working but nothing happens even the door won't lock
your door switch is the problem,where the door latch goes into the machine a little switch sites behind this a safety feature and if this is broke the machine will still switch on but will not work it will need replaced they are cheap.adrianxxx
Jun 02, 2012 | Kenmore 44072 Front Load Washer
Water will not drain out of front Load Kenmore 44072
Kenmore front loading washing machines will give you years of service. Sometimes things do go wrong, especially after the warranty runs out. Troubleshooting a Kenmore front loading washing machine could save you a lot of money on a repair bill. Before you call a service technician to fix your machine, attempt to resolve the issue through simple fixes first.
Washer Code Messages Your Kenmore front loading washing machine has an LED display that will give you error codes.
Will Not Spin If your washing machine does not spin, check to make sure the door has latched completely. Also remember that if your machine is in the SUD cycle it will not spin until it has eliminated the suds.
Washer Is Noisy
  • If the washer is making noise or vibrating, check to make sure it is still level. If it is out of level you can change this by adjusting the feet. Metal belt buckles and buttons in your laundry could be causing the noise as well.
  • Door Stays Locked After Cycle
  • At the end of the wash cycle, the lock will disengage after about 30 seconds. If it does not, it may be because the machine still detects that the water has not completely drained. Just select "Drain" and "Spin" and let the washer go through the cycle. Your door should unlock.
Nov 03, 2011 | Washing Machines
Willnotspinpumpsoundsnoisy
Depend`s...is it a front load or a top load ? Front loads can have a no spin with junk in the pump. top loads the same...if they can`t drain correctly they won`t spin correctly. If the pump is noisy, chances are something is wrong. Check the pump.
Good luck.
macmarkus :)
Dec 17, 2009 | Kenmore Washing Machines
During the spin cycle the front load washer makes a loud noise. Sounds like a bearing going bad.
you got it,and the whole tub has to be replaced because it's all one piece-mike
Jun 30, 2009 | Kenmore 44072 Front Load Washer
Kenmore front load washer #44072 drum banging noise
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
May 27, 2009 | Kenmore 44072 Front Load Washer
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
Mar 29, 2009 | Kenmore 44072 Front Load Washer
Kenmore 44072 Front Load Washer help
my kenmore washing machine has the timer out of time
Aug 08, 2007 | Kenmore 44072 Front Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
